torque spec on bolts..
Old Apr 19, 2003 | 06:03 PM
devilfish's Avatar
devilfish
Default torque spec on bolts..
..Pplate against the FW on the ZF??
thanks
Old Apr 20, 2003 | 05:04 AM
devilfish's Avatar
devilfish
Default Re: torque spec on bolts.. (devilfish)
tt
Old Apr 20, 2003 | 07:58 AM
FoolCrzy's Avatar
FoolCrzy
checking...hold on
Old Apr 20, 2003 | 08:03 AM
FoolCrzy's Avatar
FoolCrzy
Default Re: torque spec on bolts.. (FoolCrzy)
OK. From 1994 GM manual.
Clutch Pressure Plate to Flywheel.......................30lb.ft (41N*M)
Flywheel to Crankshaft.............................. ........74lb.ft (100N*M)
:cheers:
Old Apr 20, 2003 | 08:49 AM
devilfish's Avatar
devilfish
thank you :cheers:
To torque spec on bolts..
