G44 rear axle question
Old Apr 20, 2003 | 05:58 PM
Mark L. Warner's Avatar
Mark L. Warner
Default G44 rear axle question
I have an '88 'Vette coupe with the 4+3 manual trans. The RPO code in my glove box says G44, which is supposed to be a 3.07 rear axle ratio. I understood that all 4+3 coupes had the Dana 44 - which I also assumed were all posi's. Why is there no code G92 in my glovebox? What's the difference? Is my assumption correct that all '88 4+3 coupes had the Dana 44 posi with a 3.07? Any clarifications on this issue would help immensely.
:confused:
Old Apr 20, 2003 | 06:02 PM
smallblock's Avatar
smallblock
Default Re: G44 rear axle question (Mark L. Warner)
I'm not sure of the ratio...but all standards have a D44. It is posi also :)
Old Apr 20, 2003 | 06:12 PM
scorp508's Avatar
scorp508
Default Re: G44 rear axle question (smallblock)
All standard C4s from 85-88 had a Dana 44 posi rear with 3.07 rear end. The ratios changed from 89-96 but were still 44 posi units.
Old Apr 20, 2003 | 06:17 PM
vader86's Avatar
vader86
G92 is the worthless code, we still cant figure out exactly why GM even used it. You can get the 3.07 without the G92, and on some cars (automatics or verts) the G92 can be 3.07 or 2.73. It seems to vary depending on year.
So you have a D44 with 3.07, thats all you need to worry about.
Old Apr 20, 2003 | 08:11 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: G44 rear axle question (vader86)
G92 is only on the automatic cars.
You only had one choice with the manual cars.
Old Apr 20, 2003 | 09:15 PM
CFI-EFI's Avatar
CFI-EFI
As stated, G92 is a worthless designation. It means "Performance Ratio". It doesn't designate any particular ratio, only that the subject vehicle had the performance ratio option. As the "standard" ratio varies from year to year, and car to car, so does the "G92" ratio. G44 says, "3.07:1". Good luck, and...
RACE ON!!!
To G44 rear axle question
