HELP!!!! Codes......C41 H41 H72 H74
Old Apr 20, 2003 | 07:19 PM
Dougs 90's Avatar
Dougs 90
Default HELP!!!! Codes......C41 H41 H72 H74
I just started spitting these codes, and when I display the codes on the readout, when it cycles from 1 to 4.0 speedometer displays err.
Other symptoms:
1. No speedometer reading, just 0
2. English/Metric does work
3. HVAC head appears okay
4. The check guages light is also lit
Thanks,
Doug
[Modified by Dougs 90, 6:26 PM 4/20/2003]
[Modified by Dougs 90, 6:36 PM 4/20/2003]
Old Apr 21, 2003 | 12:43 AM
jimswhite92's Avatar
jimswhite92
Default Re: HELP!!!! Codes......C41 H41 H72 H74 (Dougs 90)
If I remember 41 is an ECM problem. Don't know the solution but this will TTT.
Old Apr 22, 2003 | 01:43 PM
Dougs 90's Avatar
Dougs 90
:confused:
ttt
Old Apr 22, 2003 | 11:38 PM
Dougs 90's Avatar
Dougs 90
Default Anybody????
help....please....
Old Apr 23, 2003 | 12:27 AM
shane99's Avatar
shane99
Default Re: Anybody???? (Dougs 90)
Just had a similar problem on a 92. Look at the posting under my user name. I just posted on the thread an hour ago so it shouldnt be to far down.
Old Apr 23, 2003 | 12:54 AM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
41 - Loss of ECM serial data communications.
72 - LED dimming output circuit open or shorted to ground
74 - LED dimming output circuit open or shorted to ground
Your code 41 could be all sorts of nasty things, but it could also be just a loose cable at theCCM. 72 and 74 probably indicate a bad photo diode on the dash panel.
Old Apr 29, 2020 | 08:46 AM
Donweld's Avatar
Donweld
1st Gear
Default Died On Fwy
Help ,
My 93 C-4 was going down the fwy just fine , Service engine soon light did come on then about 10 mins later just quit shut down all electrical inside car was working , Thought maybe fuel pump . would it have just shut down like that ?
Pulled up codes
1--C41
H41
H54
H74
9--H64 h72 ..
Frustrating because at least I thought it was running well before this
To HELP!!!! Codes......C41 H41 H72 H74
