Gains possible from head porting ?
Old Apr 21, 2003 | 12:11 AM
MrNuke's Avatar
MrNuke
Default Gains possible from head porting ?
I am wondering what sort of gains someone can expect from a 3angle valve job or whatever it is called. If this stuff is worth spending a few hundered on usually, or just get a new set of heads? (Which is a LOT more expensive)..
Please give actual examples if possible..
Thanks as always :cheers:
Old Apr 21, 2003 | 12:17 AM
Ray383's Avatar
Ray383
Default Re: Gains possible from head porting ? (MrNuke)
No gains from 3 angle valve job. Just no losses. Just a better seal, no better flow.
Old Apr 21, 2003 | 12:21 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You should notice some gains from a multi-angle valve job, hi-flow valves, pocket porting, chamber conditioning, port cleaning, etc.
How much gain depends on the engine setup, i.e. other mods.
Check out the results of L98 mods page on my site to see what can be gained from a set of worked L98 #113 heads.
Old Apr 21, 2003 | 12:23 AM
MrNuke's Avatar
MrNuke
Default Re: Gains possible from head porting ? (Ray383)
So you'll need a full porting job on a head to get performance out of them?
Old Apr 21, 2003 | 12:28 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Not true at all. I flowed my heads before and after the valve job. Saw an average gain of 5 cfm over the lift range, with a peak gain of 11 cfm at 0.300" lift. This was on a 4 angle seat, 2 angle valve cut. The quality of the seal is the same.
Old Apr 21, 2003 | 12:31 AM
MrNuke's Avatar
MrNuke
Default Re: Gains possible from head porting ? (CorvetteZ51Racer)
I was under the impressions that a ported set of heads can add from 15-30HP usually... Guess I was wrong.. :skep:
Old Apr 21, 2003 | 12:32 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
a 3 angle valve seat job with a 30 degree backangle on the valves plus opening up the bowls(pocket porting) will get you 15/20 HP if the head guy knows his stuff. :chevy
Old Apr 21, 2003 | 12:47 AM
Dan Parker '96's Avatar
Dan Parker '96
I think a good porting job can be worth 20-30RWHP if the cams are similar.
Just recently I hit the dyno with about 6 other Vettes. There were three that had relatively similar setups. All spec'd out according to expectation.
The engine with the headwork (and all else similar) garnered about 20 rear wheel HP versus the factory garb.
The best GM setup (LT4 heads, Hotcam, Hooker shorties, 6-speed, 52mm TB) laid down a 337hp.
The worst GM setup (LT4 heads, Hotcam, stock exhaust, 48mm TB , A4 torque converter unlocked in 2nd gear) laid down a 309hp.
The setup that really cooked was the CNC headed, CompCam (spec'd to the heads) powered '95 Vette M6 that laid down a stellar 353hp. The idle sounded stock. This was through a 52mm TB and Hooker shorties. Torque was excellent throughout the range.
I'm sure better numbers could be had, but for a "real world" vehicle I think the numbers are very good.
Back to the point, I think the dyno shows that "Stage 3 Heads" with a similar bump-stick may be worth 20hp.
Old Apr 21, 2003 | 12:53 AM
vader86's Avatar
vader86
Default Re: Gains possible from head porting ? (Dan Parker '96)
Should free up 15-20hp. Maybe more if the heads are even close to being a restriction.
Old Apr 21, 2003 | 01:00 AM
65Z01's Avatar
65Z01
MrNuke, you should get some benefit from each stage of working the heads and the max. benefit from fully working them.
Old Apr 21, 2003 | 07:03 PM
CorvetteZ51Racer
Default Re: Gains possible from head porting ? (65Z01)
Don't remember what year Nuke's car is, but if you have the 128 castings, you'll gain a little more than the aforementioned 15-20 HP because in stock form, the 128 heads are more restrictive than the TPI intake setup. That is not true of the 113's. I haven't dynoed my '87 since I ported the heads, but my flow went up ~15-20% over stock across the entire lift range. Before the ported heads, sidestepping the clutch at ~1200 RPM would bog the motor when I had the big Hooisers on the back, but after the head porting, the same procedure ROASTED the Hoosiers. Hopefully I'll get a chance to dyno the motor soon since I recently freshened it up.
Old Apr 22, 2003 | 04:12 PM
MrNuke's Avatar
MrNuke
Thanks for all the info guys.
I have an '85 with the low compression, large 74cc iron smog heads.
The '624 casting. I heard good things about porting these heads..
Old Apr 22, 2003 | 06:20 PM
CorvetteZ51Racer
I just went back through my flowbench numbers from when I ported my 128's....I gained 47.5% on the exhaust side and 17.5% on the intake side.
To Gains possible from head porting ?
