10 sec. 1/4
My question is what needs to be done to get the car to hook on the track but still allow me to drive it on the street (no nos on the street of course!)
Can the rear be tubed? I know I'll need new drive/half shafts and forged ujoints, but how much torque can the Dana 44 handle? How much before the 4+3 is turned to soup?
a 9 inch or a dana 60 will take that all day...BUT it won't be a track only car will it?
jay
As for hooking the car. I am able to pull 1.534 60' times on 10" M/T slicks on just motor this is with a D44 and 3.07 gears.
If you hit the nitrous off the line the rear will probably not take it, You have to remember that what the nitrous does it it gives you X amount of HP, in your case 300hh, but it also gives you way, way more torque so you have really at risk. You better just run motor, then step it up a little at a time. To go 300hp out of the gate, you are just asking for trouble.
That is my take. I wish you luck. :cheers:
HELPFULL HINTS
200hp shot is about the limit on the stock u-joints
never hit the giggle gas unless your in second gear and moving at least 40mph and have the engine up to at least 3500rpm with street tires
RUN THE JETS ON THE RICH SIDE FOR FUEL/AIR MIX
BACK OFF about 2-3 degrees of ignition timeing for each 50 hp of giggle gas
never hit the button in the rain!
keep the bottle out of direct sunlight, use a safety switch,THINK BEFORE USEING!
HELPFULL HINTS
Also, I was going to tap the foggers into the Super rams runners. But after thinking about it, I'm going to put them in the lifter valley under the intake man. That way I can still take the valve covers off without removing the foggers. (its also pretty stealth, except for the 2 10lb bottles in the back!)
Would I still need to do this running race gas? Like I said, no NOS on the street, unless I have the chance to spank a viper :thumbs:
theres so many factors involved I can,t give you a reasonable answer other than youll need to start low and test, on my combo, I need to use a healthy dose of octain booster, but I know several guys that get away with 92 octain pump gas
heres some info, now take this anyway you want to but paying $5 for 16 oz of octane booster when you can make 160 0z useing TOULENE and a few other additives for about $9 is nuts, now don,t get me wrong Im sure not saying you should pour 3 gallons of toulene in your gas tank and go to the track and kick butt! what I am saying is that I use a touluene/mineral spirits/mystery oil/nitromethane mix as an octane booster in my vette (when I race at the track most of the time) and it prevents detonation by raiseing the pump fuels tendency to detonate under high loads. you must read, think,blend, mix,experiment,check,re-tune, experiment, then work up to the amount you find works in your enginethis allows you to get the most out of your existing high compressions engines performance, it does NOT provide you with extra hp like nitro or a nitrous/fuel system can http://www.vtr.org/maintain/gasoline-octane.html
http://www.gnttype.org/techarea/misc/octanebooster.html
http://www.team.net/sol/tech/octane_b.html
http://www.turbofast.com.au/racefuel8.html
http://www.turbofast.com.au/racefuel4.html
http://www.zhome.com/ZCMnL/PICS/deto...etonation.html
http://www.vettenet.org/octane.html
[Modified by grumpyvette, 4:06 AM 4/22/2003]
Just like JD said & I sent him the pictures of mine:
If your car really works & you dead hook it with that much power + spray, your rears days are numbered.
Trust me, Dave :cuss
