87 MAF / Speed Density question?
Old Apr 21, 2003 | 11:45 PM
SmoothFRC's Avatar
SmoothFRC
Default 87 MAF / Speed Density question?
Hey,
My sister has an 87 vette and the service engine light intermittently comes on and it reads bad MAF, I tried cleaning the contacts and what not and still does this.
I have been looking on e-bay for a new or used MAF and have a few questions...
1. Will any MAF from any 85-89 TPI work? - Camaro, Iroc, Firebird?
2. I see people are selling Speed Density ECM's, what is involved, can i just plug in the new ecm and off with the MAF??? no other parts needed??
Thanks!
John
[Modified by 99firetruck, 4:45 AM 4/22/2003]
Old Apr 21, 2003 | 11:54 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: 87 MAF / Speed Density question? (99firetruck)
What is the troubleshooting code that you're reading?
The speed density L98 cars ('90-'91) use a different wiring harness as well as the ECM. Too much trouble to convert just for casual maintenance.
Old Apr 21, 2003 | 11:56 PM
vader86's Avatar
vader86
You must fix the code thats being set.
Replace the two relays behind the battery on the firewall, together it shouldnt be but $20. Disconnect the battery and see if the codes come back.
If they come back, replace the MAF sensor. Any 85-89 MAF should work, as to whether the F-body will work, i dont know.
Replacing the ECM will end up costing more, youd do away with MAF but you still have to buy a MAP sensor and fabricate a new intake to fit in place of where the MAF would go.
Old Apr 22, 2003 | 12:02 AM
SmoothFRC's Avatar
SmoothFRC
Default Re: 87 MAF / Speed Density question? (vader86)
Well, her boyfriend has a reader program on his laptop and he has cleared the code, but it comes back from time to time...
I dont know the exact code as it has been quite a while since we read it.
A "new" maf is like 200, where the ecm's are going for like 70. I wasnt sure what a map sensor is going to run me, and i am sure i could construct some type of intake to replace the maf....
Thanks for the reply's!
To 87 MAF / Speed Density question?
