1991 L98 Mass Air Flow Sensor
Old Apr 22, 2003 | 12:04 AM
jnsampson's Avatar
jnsampson
7th Gear
Default 1991 L98 Mass Air Flow Sensor
I'm thinking of removing the stock air cleaner and intake leading to the throttle body and replacing it with a K&N type oval air filter that is much shorter. However, I don't know if there's a MAFS inline with the air intake. Is there? If not, then I guess I can swap out air cleaners.
Thanks,
John
:cheers:
Old Apr 22, 2003 | 12:38 AM
StealDads67's Avatar
StealDads67
Default Re: 1991 L98 Mass Air Flow Sensor (jnsampson)
The 1991 L98 is a speed density setup so you dont have a MAF.
