Pic Request--MAP sensor mounting flange
Old Apr 22, 2003 | 04:06 PM
HighHopes85's Avatar
HighHopes85
Default Pic Request--MAP sensor mounting flange
If anyone has a close-up of the MAP sensor mounting flange on a 90-91 stock upper, I would appreciate it. Want to see if it is possible to modify my pre-90 or if I just need to buy the correct one.
I am most interested with the sensor off, so if anyone has a pic of it, either email it to me at msandine@purdue.edu or post it here. And actually, I am most interested on how far the vac port of the MAP goes in before it hits the O-ring(i.e. does the O-ring hit the end of the vac port or does it actually slip down the collar some).
TIA, -Matt
