rear spring question
Old Apr 22, 2003 | 04:40 PM
larryfs's Avatar
larryfs
Default rear spring question
can someone with patience pls explain the rear spring setup to me.
is the spring pushing down or up?
how will longer bolts lower the rear?
yeah, I know ..... but I'm not familiar with the C4 suspension... as least not yet.
Old Apr 22, 2003 | 05:32 PM
Raistlin's Avatar
Raistlin
Default Re: rear spring question (larryfs)
The spring pushes down, the wheel is suspended above the spring. When the weight of the car rests on the wheel, the spring is pushed up and compressed. The wheel is mounted on top of the spring. If you lengthen the distence from the spring to the wheel, it will sit higher in the wheel well.
Old Apr 22, 2003 | 10:55 PM
larryfs's Avatar
larryfs
Default Re: rear spring question (Raistlin)
I had to read that a few times, but it all makes sense now.
I really have to review the IRS setup to understand the car.
thx!! :seeya
Old Apr 22, 2003 | 11:32 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Yeah the spring puses down. If you ever try to remove that spring bolt, you better have some kind of jack holding it, because that sucker can take your head off.
Old Apr 23, 2003 | 10:46 AM
Raistlin's Avatar
Raistlin
Default Re: rear spring question (Mr Mojo)
Since my ability to express my ideas in words is limited, I decided to try pictures. Well, I found I'm lacking there as well. ;)
The spring is allways compressed the same amount for a given weight. In it's natural state, the end near the wheel would want to drag along the ground. The spring is fixed to the center of the car.
When you add a longer red bolt, your "pushing" the wheel higher in the air. Remember, the weight doesn't change, so the spring is still compressed the same amount.
Hope this is a little less cryptic...
-Stephen
To rear spring question
