Fuel Pressure
Old Apr 22, 2003 | 05:17 PM
Mark L. Warner's Avatar
Mark L. Warner
Default Fuel Pressure
I have an '88 4+3 coupe with: cold air induction, 52 mm TB, Big Mouth manifold and Large Tube Runners, ported plenum, balanced Bosch fuel injectors (22lb), GN fuel pump, true dual exhaust with H-pipe, MSD, AIR pump delete, 1.6 roller rockers, and the usual other minor stuff. I currently have the fuel pressure set a 50 psi @ WOT, and I do not have much by way of access to diagnostic tools. Any comments on current fuel pressure, and what about when I port and polish my heads and add the ZZ9 cam and mini-ram intake? :steering:
