"Help" Code 62
Old Apr 22, 2003 | 05:56 PM
ziggysred92's Avatar
ziggysred92
Default "Help" Code 62
I had the 92 in for the annual inspection today. The security keeps flashing along with SYS on dash. The Service ASR comes on also. The dealer checked codes and said there are no stored codes in system and SAR Code 62 TAch Pulse Fault. He tried to explain it but am confused. They said the module to fix the problem will cost over $400.00 ANY SUGGESTIONS
Old Apr 22, 2003 | 06:30 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: "Help" Code 62 (ziggysred92)
Go here to find out more about your codes:
http://www.c4vettes.com/ecm.htm
Code 62 is oil temp high. You may have faulty wiring or sensor.
Check for a bad ground or possible battery/alt issues as you seem to have a lot of lights flashing.
