Cap and rotor
Old Apr 23, 2003 | 06:49 PM
detto's Avatar
detto
Default Cap and rotor
Time to replace the cap and rotor in my L98.
I started to look around and figure that maybe I should get another coil also!?
Any suggestions on kits from Accel / MSD or something??
Thanks for any input :)
Old Apr 23, 2003 | 07:02 PM
Rob90's Avatar
Rob90
Default Re: Cap and rotor (detto)
I have the Hypertech cap and coil. Got mine from Summit
http://store.summitracing.com/defaul...t=Cap+and+coil
[Modified by Rob90, 6:03 PM 4/23/2003]
Old Apr 23, 2003 | 07:13 PM
FlyboyZR1's Avatar
FlyboyZR1
Yes definitely get the Hypertech cap/rotor/coil from Summit. However, do not use the nylons screws that come with the rotor. They're known to work themselves loose, ... re-use the metal ones from your GM rotor. :)
[Modified by FlyboyZR1, 6:14 PM 4/23/2003]
Old Apr 23, 2003 | 07:44 PM
scorp508's Avatar
scorp508
Save yourself some money and get a Conrad cap & rotor from Autozone. Its around $12-$15 depending on what your Autozone has its price set at. It has brass terminials and metal screws.
p.s.
The MSD HEI coil and low resistance bushing is what I run. Looks stock from the outside.
[Modified by scorp508, 7:45 PM 4/23/2003]
Old Apr 23, 2003 | 10:42 PM
dgoodhue's Avatar
dgoodhue
Default Re: (scorp508)
p.s.
:iagree:
Old Apr 24, 2003 | 12:23 AM
WhiskeyPapa's Avatar
WhiskeyPapa
Default Re: (dgoodhue)
:iagree:
Old Apr 24, 2003 | 01:05 PM
detto's Avatar
detto
Hmm..! think I willl go with this kit from Midamerika..!
Its hard to fin MSD in a kit.
Thanks all!!
http://www.madvet.com/shop?store=1&c...y=14&frame=837 http://www.madvet.com/shop?store=1&c...y=14&frame=836
Old Apr 24, 2003 | 01:23 PM
h rocks's Avatar
h rocks
Default Re: (detto)
The Accell cap is a good one, but I know two guys that had meltdowns with their coil. Just burned a hole through the top. The other two mentioned earlier are the way to go. Also, the MSD Superconductor wires are excellent.
Old Apr 24, 2003 | 01:39 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
p.s.
:iagree: If you can handle RED
Old Apr 24, 2003 | 01:43 PM
scorp508's Avatar
scorp508
Default Re: (detto)
No way! I think that coil is $65 from Summit if thats the one you want.
Old Apr 24, 2003 | 04:27 PM
HeeHaw89's Avatar
HeeHaw89
Default Re: Cap and rotor (FlyboyZR1)
[QUOTE]Yes definitely get the Hypertech cap/rotor/coil from Summit. However, do not use the nylons screws that come with the rotor. They're known to work themselves loose, ... re-use the metal ones from your GM rotor. :)
This just happened to me. Car started running bad, checked under the dist cap to find the screws had come completely loose! The car actually ran that way for a while, hard to believe but true.
[Modified by HeeHaw89, 4:28 PM 4/24/2003]
Old Apr 24, 2003 | 04:54 PM
Vetterin's Avatar
Vetterin
I had the Accel cap, rotor and super coil but they didn't last very long. Now I have the Autozone Conrad red cap and like Scorp said, it's every bit as good at about half the price. Now having a red cap with a gray super coil sticking out the top is a different matter!! :crazy:
To Cap and rotor
