t-stat housing.
Old Apr 24, 2003 | 02:38 AM
devilfish's Avatar
devilfish
Default t-stat housing.
How many gasgets is used with the thermostat? I got one big blue that fits over the t-stat? Is there supposed to be one under it as well?
[Modified by devilfish, 1:07 PM 4/24/2003]
Old Apr 24, 2003 | 07:07 AM
devilfish's Avatar
devilfish
Default Re: t-stat housing. (devilfish)
tt
Old Apr 24, 2003 | 08:38 AM
Frodo's Avatar
Frodo
One gasket is all you need. The gasket seals between the goose neck and the intake manifold, not directly on the stat. Some people don't use a gasket at all but use a bead of silicone that forms a gasket. If you use silicone be sure to allow 24 hours for it to cure before filling with coolant.
Good luck!! :cheers:
Old Apr 24, 2003 | 08:51 AM
devilfish's Avatar
devilfish
Default Re: t-stat housing. (Frodo)
thank you :)
Old Apr 24, 2003 | 09:13 AM
chucks88's Avatar
chucks88
I use 1 gasket and finger smear blue RTV on both sides of it. It may be any overkill but have had no leaks.
Old Apr 24, 2003 | 09:49 AM
devilfish's Avatar
devilfish
Default Re: t-stat housing. (chucks88)
and the gasget goes over the t-stat nothing under it against the intake manifold :)
Old Apr 24, 2003 | 10:51 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Right, place the t-stat into the depression in the intake base, install the gasket onto the base and then the goose-neck over the gasket.
You don't want any coolant to leak out of the intake, but if a little leaks around the t-stat into the engine it's no big deal, right.
[Modified by 65Z01, 9:54 AM 4/24/2003]
Old Apr 24, 2003 | 11:15 AM
BIG K's Avatar
BIG K
devilfish, I just went through the same thing after engine rebuilt.
First, I tried a silicon gasket which said do not use RTV(it was very thick, over .5 cm). I't didn't work. One of the Forum members explained that GM housings warp or bow. You need to check this with a streight edge. To fix this he said use a belt sander.
I threw out the $5.00 gasket and bought an $.89 gasket. RTV on both sides. Drove it after 12 hours cure(I know, I know, I should have waited 24).
I have over 300 miles on it now.
Hope this helps! :thumbs:
Old Apr 24, 2003 | 11:50 AM
devilfish's Avatar
devilfish
Default Re: t-stat housing. (BIG K)
thanks :seeya
To t-stat housing.
