LT4 Service engine light.......
Old Apr 24, 2003 | 04:51 PM
Vmc's Avatar
Vmc
Default LT4 Service engine light.......
Question - Why with 19,000 miles would I get the service engine light?
Is there a self-diagnostic, so I can see if there is a code?
What is "USUALLY" the problem?
Can you guys help me out with this ine?
Thanks and :cheers: In advance!!
:seeya
Old Apr 24, 2003 | 06:25 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: LT4 Service engine light....... (DCTC)
The light has to do with emissions. Maybe a bad sensor. If you just got gas and did tighten the cap all the way, that can cause it to come on. Re-tighten and drive for a few on-off trips. Then clear the code out of the computer and see if it comes back on. Otherwise, you need a scanner to pull the code. Autozone can do it for free, or your mechanic should have have a scan tool to get the code.
Old Apr 24, 2003 | 09:53 PM
Vmc's Avatar
Vmc
Default Re: LT4 Service engine light....... (Gary96LT4)
Gary...
Thanks for the info....but how do you clear the code?......I need a vacation... :lol:
:seeya
Old Apr 24, 2003 | 11:59 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
DCTC,
You have to have an OBDII compatible scan tool to do code diagnostic work on 1994 and newer Corvettes...
Means hunt up a close Forum buddy that owns a scan tool or take a trip to a dealer, I think.
Old Apr 25, 2003 | 11:43 AM
TravisD's Avatar
TravisD
Something like this is only about $130 from the local auto parts store: http://www.actron.com/cgi-bin/web_st...=8308715_12009
Many parts stores will read and reset the codes as well.
It may also clear on it's own if the problem corrects itself, and you go thru enough drive cycles (i.e. turning the key on and off won't do it, but a few half hour drives might).
Old Apr 25, 2003 | 12:24 PM
ZZZASY's Avatar
ZZZASY
Default Re: LT4 Service engine light....... (TravisD)
You can clear the codes by disconnecting the battery for awhile; but buying a scantool is a must if you are going to do most of your own work. I bought a scantool off of a group purchase (gp) on the forum. Not sure if the gp is still available, but if not I'm sure there are a lot of others on the forum who still need one. Maybe a new gp could be arranged.
ZZZASY
'96LT4
Old Apr 25, 2003 | 01:17 PM
Gary04Z06's Avatar
Gary04Z06
Gary...
:seeya
Sorry, Forgot the mention how to clear the codes. Someone already answered for me (dissconnect the battery for a minute or two).
A Scan toll is a big help working on these cars.
Good luck!! :cheers:
Old Apr 25, 2003 | 11:37 PM
Vmc's Avatar
Vmc
UPDATE....................
Well, you guys were right. all I had to do was disconnect the battery for a bit and when I started it up again...No Problemo...drove it all the way to Venice and back, and smooth sailing.
Thanks for all the help guys!!!
:cheers: :cheers: :seeya
Old Apr 26, 2003 | 12:08 AM
LT4Sam's Avatar
LT4Sam
I would still pull the code, the light won't just go on for no reason and it should have stayed in memory no? I just pulled a code on mine today and found out my MAP sensor was screwed up, the car ran fine but it's better now.
Sam
Old Apr 26, 2003 | 01:42 AM
GlockLT4's Avatar
GlockLT4
normally i would say it was an EGR code from the highway, but we LT4 guys don't have EGR :D
Old Apr 26, 2003 | 09:33 PM
Wadoka's Avatar
Wadoka
Default Re: LT4 Service engine light....... (GlockLT4)
[QUOTEnormally i would say it was an EGR code from the highway, but we LT4 guys don't have EGR :D [/QUOTE]
Yeah, and your MAP sensor only backstops the MAF sensor and watches over spark control.
There's a new trick for a newbie with an LT4 - "Gotta be your EGR. Whaddya mean, it's missing?" :D :D :D
To LT4 Service engine light.......
