U-joints..
Old Apr 24, 2003 | 05:01 PM
devilfish's Avatar
devilfish
Default U-joints..
Got a probleme..
Im about to replace my u-joint on the driveshaft on the dana44 side.
When I get the u-joint installed I got stiffness in the joint. There is stiff/binding movement in the u-joint.
Do you got anny procedure for seating the Joint in the caps, got the joints to move freely?
Or mayby I got wrong u.joints?
What is the partnumber for the drive shaft u-joint? THanks
[Modified by devilfish, 11:38 PM 4/24/2003]
Old Apr 24, 2003 | 05:38 PM
devilfish's Avatar
devilfish
Default Re: U-joints.. (devilfish)
tt
Old Apr 24, 2003 | 05:43 PM
scorp508's Avatar
scorp508
You may need step 39.
http://personal.tmlp.com/scorp/vette...ts/ujoint.html
Old Apr 24, 2003 | 05:52 PM
devilfish's Avatar
devilfish
Default Re: U-joints.. (scorp508)
how smooth should the u-joint be? Is a little stiffnes OK?
And can you explain "What I do is take something like a chisel with a very blunt end on it, and whack it with a hammer".
Whats a chisel? ( not to god at English ).
Old Apr 24, 2003 | 05:54 PM
devilfish's Avatar
devilfish
does ot matter witch way you isntall the u-joint. Can you put it on "wrong"?
Old Apr 24, 2003 | 06:00 PM
scorp508's Avatar
scorp508
Like this, but a more blunt (dull) endge on it.
Old Apr 24, 2003 | 06:17 PM
Mike's 86's Avatar
Mike's 86
Nicejob with the pics Scorp :cheers:
Old Apr 24, 2003 | 06:38 PM
scorp508's Avatar
scorp508
Default Re: U-joints.. (Mike's 86)
Thanks. :) Just don't use that brand of u-joints you see in the pics!
Old Apr 24, 2003 | 06:52 PM
Curveit's Avatar
Curveit
:thumbs: Very nice job on the pics, and instructions!!! Well done!!!
:chevy
Old Apr 24, 2003 | 07:19 PM
devilfish's Avatar
devilfish
your picture libary must be huge!! :eek:
Thanks.. I will tap it a little...
( i use GM u-joints )
Old Apr 24, 2003 | 07:26 PM
scorp508's Avatar
scorp508
It should hopefully work, just make sure you tap it on a meaty part of the joint. When you press the caps in the bearings all get loaded up against one end causing extra friction. Knocking it back a tiny amount frees them up.
Old Apr 24, 2003 | 09:15 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
That web site saved my butt last year during autoshop :thumbs: :cheers:
Old Apr 24, 2003 | 09:23 PM
Curveit's Avatar
Curveit
I just went and picked up my U-joints that I had ordered. They look a whole lot like the ones in your pics. Mine are Brute Force from Auto-Zone. A local Vette racer told me they were the ones to get. Do I have the wrong parts or what? :confused:
Old Apr 24, 2003 | 10:05 PM
scorp508's Avatar
scorp508
Default Re: U-joints.. (Curveit)
Those are the ones in the pics. They are the "right" parts, but they are much weaker than the factory Spicer ones. If you do any drag racing you may want to reconsider using those. Otherwise you should hopefully be ok.
Old Apr 24, 2003 | 10:09 PM
NUckINg FuTS's Avatar
NUckINg FuTS
They should seat themselves after some driving. :cheers:
Old Apr 24, 2003 | 11:13 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
NOOOOOO!!!!!!!! Take them back!!!!!! They are garbage. They will work if all you do is street driving, but do not even think about going to the drag strip (even with just street tires).
I got around 5 passes at the Bowling Green track before snapping one of mine, and that track if far from being well prepped.
Old Apr 25, 2003 | 08:23 AM
The Hobbit's Avatar
The Hobbit
Great write up, you should work for Haynes
To U-joints..
Old Apr 25, 2003 | 08:55 AM
Juliet's Avatar
Juliet
Nice work Scorp!
When I redid the rear suspension in the '87 (and '70 also) I used a really big U clamp to get the caps to seat and click in. It just seemed a little more controlled than hammering on it. :eek: ~Juliet
Old Apr 25, 2003 | 11:48 AM
edsalinas's Avatar
edsalinas
Excellent work Scorp, thanks for all the great info.....
P.S.
Spicer rules ! ! ! ! ! !
:thumbs:
Old Apr 25, 2003 | 04:20 PM
devilfish's Avatar
devilfish
Default Re: U-joints.. (edsalinas)
THe "tap" trick did it :) THanks scorp for spending your valuable time on me :D
THanks to you all :)
