Questions on rack & pinion replacement
Old Apr 25, 2003 | 02:54 PM
Greg's '88's Avatar
Greg's '88
Default Questions on rack & pinion replacement
I will probably be changing the rack & pinion in my '88 Vette this weekend. I seem to remember that someone posted a nice write up on the entire procedure...with pictures. I thought I found the link but it was no longer active. Is there a new link to the same information?
The key piece of information I'm looking for is the size of the pickle fork I'll need to pop the tie rod ball joints out with. Anyone know? I think the write up (that I can't find) stated the size that is needed.
Thanks in advance for your help.
Greg Sullivan / Canyon Lake, CA.
Old Apr 25, 2003 | 04:26 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Questions on rack & pinion replacement (Greg's '88)
I think that was or used to be Craig Marchos tech page for the rack replacement.Btw I didnt use a fork but a 6 inch puller and popped the tie rods off easily.I already had that in my tool box and it did the job.
Btw,if you buy a tie rod puller from an auto parts store,it may not fit.I found the pitman arm puller,which is like the tie rod puller,only larger,will fit the tie rods on the Vette easier.A tie rod puller I bought once but took back wouldnt fit.Mustve been for cars with smaller tie rod ends bit it never specified what cars to use it on.
Sorry dont know the fork sizes...I never used them.
Old Apr 26, 2003 | 05:17 AM
jtfrog's Avatar
jtfrog
if you search under archives for user jtfrog i have the post. If you cant find it let me know and i can probably send it via email. Try this also
http://tempcorvetteforum.net/c4/marc...k_replace.html
Old Apr 26, 2003 | 09:06 AM
SS409 425HP's Avatar
SS409 425HP
I replaced my rack and pinion last year. I did not use a "fork" to remove the tie rods. I used my wife's blow dryer to heat the area and then hit it with a brass hammer. You have to loosen the nut until its flush with the end of the stud before you hit it. The blow dryer doesn't put out enough heat to damage anything. The tie rod end popped out with just a couple of light taps with the hammer. The aluminum housing expands faster than the steel rod end with a little heat.
Old Apr 26, 2003 | 10:19 AM
Greg's '88's Avatar
Greg's '88
Default Re: Questions on rack & pinion replacement (SS409 425HP)
Wow! I love this forum! Having access to this much information makes working on my Vette so much easier. Thanks to each of you for the great ideas and feedback.
By the way, I found the link that is still active. Here it is: http://temp.corvetteforum.net/c4/mar...k_replace.html
Greg Sullivan
Canyon Lake, CA.
[Modified by Greg's '88, 7:26 AM 4/26/2003]
To Questions on rack & pinion replacement
