LT1 fuel pressure testing in-progress, will report results
10 more minutes drops to 33psi
10 more minutes drops to 31psi
10 more minutes drops to 29psi
total: 45 minutes drops from 41psi to 29psi
Start engine drops it from 41psi to 37psi and holds steady @ 37 while idling
Pull vacuum line off FPR while engine idling brings it up to 45 or 46psi
Engine was not at full operating temp for the above, going to drive it for awhile and re-test w/ hot engine.
Not going to do the gauge-on-windshield driving observations yet, perhaps tomorrow if it seems necessary.
[Modified by Lone Ranger, 1:38 PM 4/26/2003]
Key-on pressurizes it to 41psi, 15 minutes later she's still holding 41psi-- no bleed-down drop apparent on the gauge. I didn't wait any more, since it appeared that with the system hot it holds pressure with little or no bleed-down (at least for fifteen minutes).
Engine start-up and idle dropped it from 41psi to 36psi-- no major difference from the cold test. Engine idling and pulled vacuum line off FPR caused it to go up to 44psi, about 1 psi or so less than when the engine was idling 'cold' (warming up).
All of the tests both cold and hot seem to be within spec, AFAIK.
How come it holds pressure better when hot than when cold, anyone know?
[Modified by Lone Ranger, 5:57 PM 4/26/2003]
