84 rear spring on an 88??
Old Apr 26, 2003 | 03:48 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default 84 rear spring on an 88??
we some how aquired a brand new rear mono spring for a c4. Its labeled 84 rear. Will it fit my 88? what kind of effects or problems could i expect? Thanks alot
Milan
:cheers:
Old Apr 26, 2003 | 04:22 PM
vader86's Avatar
vader86
Default Re: 84 rear spring on an 88?? (88'Cubka)
I dont think it will fit, they changed the suspension geometry in 88.
Old Apr 26, 2003 | 04:52 PM
Frizlefrak's Avatar
Frizlefrak
Nope. But you shouldn't have any trouble selling it. List it on eBay
Old Apr 26, 2003 | 08:07 PM
Fast Glass's Avatar
Fast Glass
Default Re: 84 rear spring on an 88?? (vader86)
I know it will definately fit an '87 cause thats what I'm running. What exactly did they change in '88? Just wondering because I've got an '84 rear spring and a mid 90s Dana 44 all bolted back there with no issues. All seemed to fit nicely.
Old Apr 27, 2003 | 12:29 AM
vetracer's Avatar
vetracer
'84's had very stiff rear springs. I don't think that is what you want on your '88. If you have ever seen one of the spring rate charts posted here on the forum you will see that GM decreased spring rates over the years, with the base '96 being the lowest spring rate. The '84 z51 was the highest, and the '84 base spring was stiffer than the '85 z51. I have an '85 z51 in front and a base spring in the rear of my'86. I tried the '85 z51 rear spring and it was way too stiff. The z51 front/base rear rides and handles great on my car. So to answer your question, I don't see any reason why you would want to make the rear stiffer.
Also, I think you can swap rear springs for all C4's but front springs are different for 84-87 and 88-96.
[Modified by vetracer, 10:31 PM 4/26/2003]
Old Apr 27, 2003 | 06:56 AM
BIG JIM 54's Avatar
BIG JIM 54
I've had an '84, an '85 Z-51 and my '87 Z-52 is by far the roughest riding of the 3. Might be those damn Sumatomo's too.
BIG JIM
To 84 rear spring on an 88??
