Headlight Repair
Old Apr 26, 2003 | 05:05 PM
Skydiver's Avatar
Skydiver
Default Headlight Repair
The passenger side headlight on my 87 only goes down if you open the hood and tap the electric motor with a flashlight or something heavy. I have the headlight motor open right now and was wondering if anybody could tell me which contacts need to be cleaned in order to get it operating properly. Additionally, what should I use to clean them? Thanks in advance.
Old Apr 26, 2003 | 08:10 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Headlight Repair (Skydiver)
:cheers: Your question raises a myriad of other questions....Generally the problem with the headlights is not in the motor, but in the bushings inside the drive gear.
Is you motor (headlight) running when it won"t close...if it is it is likely the bushings.
If it isn't, unfortunately I can't help you, butt wait a few minutes. Someone is bound to come along who can :D
Jack
Old Apr 26, 2003 | 08:13 PM
Skydiver's Avatar
Skydiver
No, the motor does not seem to run after the headlight has lowered. I thought this was an odd problem also. Thanks for the insight, but I don't think it is the bushings.
Old Apr 26, 2003 | 08:34 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Clean the brushes and their contact points, use fine sandpaper or steel wool and rinse with electrical component cleaner. You can find the cleaner at a parts store near the brake clean, carb. cleaner, etc.
Old Apr 26, 2003 | 08:52 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Headlight Repair (Ski2Tee)
This may well be the correct solution, but I just thought of something else ( I am electronically impaired, if it doesn't take a wrench, I can't fix it :rolleyes: )
But there are "stops" that sense the pressure when the light is fully opened or fully closed that shut the current off to the motor. Perhaps the "stop" is out of adjustment!
Sorry, now I have probably really confused you :rolleyes:
:seeya :steering:
Jack
Old Apr 26, 2003 | 09:12 PM
Skydiver's Avatar
Skydiver
JackDaRoofer, any idea where the stops are? I am electronically impaired also. There are alot of little brass or copper looking contact points in the motor.
Thanks.
Old Apr 27, 2003 | 10:25 AM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers:
I am heading over to my garage to clean the dirt off from yesterday's Skyline cruise (great FUN by the way)
I'll check the book and get back to you later if someonelse doesn't give you the answer before then
:D :steering:
Old Apr 27, 2003 | 11:02 AM
nobodyunknown's Avatar
nobodyunknown
Check this thread.
http://forums.corvetteforum.com/zerothread?id=501168
Old Apr 27, 2003 | 10:10 PM
LaVidaLoca's Avatar
LaVidaLoca
Default Re: Headlight Repair (nobodyunknown)
Thanks for finding the old post Greg.
Skydiver; if you still have questions send me an email. I took my motors apart so many times that I can now do it in a few minutes. This is an electrical problem common on pre 88 motors. After cleaning the brush contacts as suggested above and modifying mine to a 2 wire system the lights are now very reliable. :yesnod:
[Modified by LaVidaLoca, 9:14 PM 4/27/2003]
To Headlight Repair
