change oil light?
Old Apr 26, 2003 | 08:04 PM
fiberglasscoffin's Avatar
fiberglasscoffin
Default change oil light?
on a 94 how do i get rid of the change oil light? :steering:
Old Apr 26, 2003 | 08:45 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Default Re: change oil light? (fiberglasscoffin)
This is how its done on my 92.
1.Turn ignition "ON", but do not start engine.
2.Press the "ENG/MET" button and release, then, within 5 seconds, press it again.
3.Within 5 seconds of Step 2, press and hold the "GAUGES" button. While the button is held, the "Change Oil" indicator will flash.
4.Continue holding the "GAUGES" button until the "Change Oil" indicator stops flashings and goes out, this should take about 10 seconds. If it does not successfully reset, turn ignition "OFF" and repeat the procedure from STEP 1.
Old Apr 27, 2003 | 06:53 PM
fiberglasscoffin
Default Re: change oil light? (Dudeurgettnavette)
thanx worked perfect :party:
To change oil light?
