Headlight door adjustment
Old Apr 26, 2003 | 09:37 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Headlight door adjustment
I'm sure I saw this somewhere but my search drew a goose egg. The right headlight door on my 87 is low on one corner and high on another. Looks :eek: How do I adjust em? :lurk:
Old Apr 27, 2003 | 12:25 AM
MyZ51's Avatar
MyZ51
Default Re: Headlight door adjustment (corvetteronw)
Take the covers off that cover the headlights from underneath. I think there are four screws holding them on.
You have to get the headlights to stop in about the halfway open postion, you do this by first pulling out the headlight switch like your turning them on, once the lights get halfway, push the switch in to the parking light position, they will stop there.
Once you have remove the headlight covers you will see two bolts on the front and two bolts on the back for your adjustment.
Both of mine were way off when I got mine too.... drove me crazy so had to fix it. :smash:
Old Apr 27, 2003 | 12:34 AM
vetracer's Avatar
vetracer
There are also manual ***** next to the headlight motor you can turn to get the headlights partially open to make the adjustment.
Old Apr 27, 2003 | 06:10 PM
corvetteronw
Cruise-In VIII
Default Re: Headlight door adjustment (vetracer)
A big thank you! It worked and they look much better now! :party:
To Headlight door adjustment
