Brake problem
Old Apr 27, 2003 | 06:19 PM
mk842766's Avatar
mk842766
Default Brake problem
Got a strange problem with my brakes on my 85...just cleaned up all the suspension and brakes, installed new pads, bled the brakes. Now when I take it out to test the brakes, thes seem slow tostop the car. I have to pump them once, and only once, and they seem to grab a lot better. If I don't pump them the one time, and continue to push on the pedal, it almost gets to a stop, and then the motor will rev up about 300 rpm, and start moving again. If I pump the one time, they seem to stop just fine. I've beld them again, but the same problem. I could probably live with pumping them once, but why does the moter rev when I try to stop??? :crazy: :crazy:
Old Apr 27, 2003 | 08:08 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Brake problem (mk842766)
:cheers: Sounds like a vacuum leak!
Did you disturb the hoses around the booster?
:seeya
Old Apr 28, 2003 | 09:03 AM
mk842766's Avatar
mk842766
Default Re: Brake problem (jackdaroofer)
Nope, just changed the brakes....they were working fine before....I'll check for a vacuum leak somewhere around the brakes.....
Old Apr 28, 2003 | 09:56 AM
ittlfly's Avatar
ittlfly
If they were working fine before the job and not working correctly after, then it is probably something you did/ didn't do. I assume you bled them in the correct order. I agree with Jack as it sounds as if air is trapped in the system. Also, did you change out the rubber brake lines? The inner rubber may be collapsing causing a restriction of fluid. However, I'm leaning more toward trapped air. Bleed her again. :D
Old Apr 28, 2003 | 12:35 PM
John Row's Avatar
John Row
It's possible that when you were bleeding the brakes that you pushed the master cylinder piston past it's wear area and scuffed the o-rings.
When you pump the brakes the second time, do they stay firm or does the pedal slowly go down. This would be an indication that the fluid is leaking around the seals.
If the fluid in the MC reservoir got low while you were bleeding the system some air could have been sucked in and be pretty far up in the brake lines.
Old Apr 28, 2003 | 12:42 PM
mk842766's Avatar
mk842766
Default Re: Brake problem (John Row)
They stay firm, and stop as before...it's just the slow stop if I don't pump, and the increase in engine RPM that worry me...I would agree that it sounds like vacuum, but I always thought that plugging a leak would increase the RPM...therefore, I would assume I have a leak, and when I depress the brake hard enough, I plug that leak, thus resulting in an increase in RPM. Sounds like a booster problem to me, but the brakes are not hard to engage???? hope to chase it down...... :banghead:
Old Apr 28, 2003 | 07:06 PM
72tccracer's Avatar
72tccracer
Strange mine are doing about the same thing. Not sure about the 300 rpm increase though. I bled mine and they felt fine until I started the car and they got real soft. Bled them again not much better. I ran the race that I was in at Atlanta and about half way through the pedal hit the floor at the end of the back straight at 155. :eek: :eek: :eek:
Saturday I put all new pads on and bled them again still seem the same. I was going to just replace the master and front calipers and hope this works. Its not a good feeling doing 150 and having your foot go to the floor.
If it was a vaccum leak would'nt that make the pedal harder to press??
Any info would be greatly app.
Chuck http://www.tccracing.com
#72 :flag
[Modified by 72tccracer, 6:07 PM 4/28/2003]
To Brake problem
