Dana rear end question
Old Apr 28, 2003 | 07:33 PM
sebvette's Avatar
sebvette
Default Dana rear end question
Ok, sorry for so many questions on the Dana 36 rear end's but I want to make sure I get the correct rear end. I hear people saying that a 3:73 would put the car at to high of an RPM on the hiway at 60. Would a 3:54 be better on hiway? what RPM would it typically be? How muc top end would I lose? how mcuh better out of the hole would a 3:73 be VRS. 3:54? Thanks for your patients guys and for the replys.
1992 LT1 Corvette :confused:
Old Apr 28, 2003 | 07:55 PM
redcorvettedave's Avatar
redcorvettedave
Default Re: Dana rear end question (sebvette)
I just put in 3.54s........ at 2600 rpms I'm around 70mph in OD...you probablly have higher rpms with 3.73s But let me tell you thats the best mod IMO hands down!!!!!!! the car will come alive!!!!! :auto:
Old Apr 28, 2003 | 07:58 PM
JayH's Avatar
JayH
To figure out new RPM's for a new gear, use a simple ratio:
old ratio new ratio
old RPMs X
Cross multiplying gives (with 3.07 as old gear ratio and 3.73 as new ratio and 2000 rpm's at 65mph:)
3.07X = (3.73)(2000)
3.07X = 7460
X = 2429.96 RPM's for 3.73 gear ratio at 65MPH
Jay
Old Apr 28, 2003 | 08:00 PM
MrNuke's Avatar
MrNuke
Default Re: Dana rear end question (redcorvettedave)
:iagree: can't wait to swap from 3.07 to the 3.45 dana44 soon.. Should let the car get in the power band and stay there waaay quicker..
Old Apr 28, 2003 | 09:17 PM
CFI-EFI's Avatar
CFI-EFI
Try driving your car in drive (direct) at high speeds. Experience different cruise rpms, so you'll know how they feel, and how YOU feel about them. Analize your driving habits and your tolerence for different cruize rpms. Do some math. What one guy (me, maybe) loves, you may hate. Good luck, and...
RACE ON!!!
Old Apr 28, 2003 | 10:13 PM
redcorvettedave
Default Re: Dana rear end question (CFI-EFI)
quote:
________________________________________ _____________
________________________________________ ________________________
:iagree: try launching and driving those 3.07s in "D" you'll might have all the gear you want...IMO 3.07s is the best gear for HWY driving....but for "A" kicking acceleration you GOTTA get 3.54s or 3.73 for an A4..
Old Apr 28, 2003 | 10:31 PM
az28's Avatar
az28
Is the dana 36 the rear end used in automatic cars? :flag
Old Apr 28, 2003 | 11:00 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Dana rear end question (az28)
Yes, and '84 models.
I would vote for the 3.54's for the Automatic. :D
Old Apr 28, 2003 | 11:39 PM
vader86's Avatar
vader86
Default Re: Dana rear end question (Vette92)
Why does everybody worry about losing top-end? When are you actually gonna be driving at 150+mph?
If you do alot of hwy driving, go 3.54. Otherwise 3.73.
Old Apr 28, 2003 | 11:57 PM
hookedup's Avatar
hookedup
Default Re: Dana rear end question (vader86)
:iagree: well said vader.
Dave :thumbs:
Old Apr 29, 2003 | 12:30 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
There you go.........
:thumbs:
[Modified by edsalinas, 10:30 AM 4/29/2003]
Old Apr 29, 2003 | 02:24 PM
BlackBeast2's Avatar
BlackBeast2
So, a '95 6spd has the D44 ?
Old Apr 29, 2003 | 02:48 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Dana rear end question (BlackBeast2)
Unless someone swapped it out, yes.
Old Apr 29, 2003 | 04:57 PM
vettef6's Avatar
vettef6
Is your rear end quiet or does it make noise after installing aftermaket gears as Richmond Gears says it will?
Old Apr 29, 2003 | 05:02 PM
STL94LT1's Avatar
STL94LT1
Default Re: Dana rear end question (vettef6)
If possible get a Dana gearset, they are as quiet as the originals.
Old Apr 29, 2003 | 08:16 PM
RadPolo96's Avatar
RadPolo96
I put in aftermarket 3.54's, they make no sound. Richmonds suppossedly make alot of noise, thats why I stayed away from them. I just got some US gears. They work great :thumbs:
Old Apr 30, 2003 | 01:37 AM
vettef6's Avatar
vettef6
Default Re: Dana rear end question (RadPolo96)
where did you get your gears from and how much did you pay?
Old Apr 30, 2003 | 04:44 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I have 3:73's in my Dana 36...all that's been said is true...I cruise at 70 mph around 2500 rpm..no biggie...took an 1800 mile road trip last year and am heading to Cruise In IV in 3 weeks, about 1500 miles round trip...here's the bottom line..if you just want to perk things up a bit go with 3:54's...if you enjoy drag racing at all or want some serious snap go with 3:73's and a Transgo shift kit like me...the highway part is not an issue... good luck.. :D
Old Apr 30, 2003 | 10:29 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Dana rear end question (golfboy1)
For YOU!
To Dana rear end question
