Idle problem w/383...Help !!
Old Apr 28, 2003 | 08:05 PM
Vette#4's Avatar
Vette#4
Default Idle problem w/383...Help !!
My 383 has developed a severe idle problem...215/222 cam, new BBK 52 mm, LPE box pleneum, #24 injectors, TPIS level V chip. Car runs great but won't hold an idle unless I unplug the MAF. I have the IAC at 45, TPS at .58, varied the fuel pressure from 20-50 psi, there are no vaccum leaks (19 inches @ idle-maf unplugged) Open or closed loop does the same thing, my fuel integration is low-108 or so, and I know that has to be some of my problem. So far have swapped out the ecm, MAF sensor, IAC motor, swapped in a stock chip and checked the volts to the TPS (5 volts unplugged) with no luck Any opinions or hints or anything would be greatly appreciated :banghead:
Old Apr 28, 2003 | 11:56 PM
GlockLT4's Avatar
GlockLT4
Default Re: Idle problem w/383...Help !! (Vette#4)
Maybe you got a bad new MAF, but if you unplug that and it makes your car run better, it's most likely the problem.
