Remove dashboard from 1985 Vette
Old Apr 29, 2003 | 07:07 AM
carlislevette85's Avatar
carlislevette85
Cruising
Default Remove dashboard from 1985 Vette
Can anyone tell me exactly what's involved in removing the original dashboard from my
85 vette? It's damaged and I want to replace it with one I got locally.
Old Apr 29, 2003 | 08:11 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Remove dashboard from 1985 Vette (carlislevette85)
Pretty easy. There's a bunch of screws going directly up into it. Check carefully on the passenger side around the loaf. I don't remember exactly how many screws (8?). Search the archives for this. After those are all out, simply pull firmly directly backwards on the dash in a purely horizontal motion. It's made of styrofoam, and held on by little clips that curve forward about 1 inch. DO NOT pull up on the dash, it'll probably break these clips from the foam. As you pull it back about an inch, you should feel the clips release. If you have non-bose setup, you might have to disconnect the dash speakers before removing it completely (not sure if these are attached to the speaker grilles or not, because I have bose). :cheers: Before installing the new one, check the clip attachment points on the car and make sure they're clear of corrosion.
[EDIT]
Don't forget to remove the two screws up by the defroster vent also.
[Modified by CentralCoaster, 5:14 AM 4/29/2003]
