Changing gears
Old Apr 29, 2003 | 12:10 PM
Strick's Avatar
Strick
Default Changing gears
Hi Guys,
I want to start getting ready to change my gears to the 410s. Besides the ring and pinion, what do I need to replace, ie. bearings, gaskets, crush bearings, etc. Is there anything I should improve or replace while I'm in there?
Thanks for the come backs
:grouphug:
Old Apr 29, 2003 | 12:20 PM
vader86's Avatar
vader86
Default Re: Changing gears (Strick)
U-joints wouldnt be a bad idea.
Old Apr 29, 2003 | 12:56 PM
STL94LT1's Avatar
STL94LT1
At the time of my gear install my car was very low milage, so I didn't change the bearings, just the seals. There is no gaskets to change, and you should get a new crush sleeve with the gear set.
Old Apr 29, 2003 | 01:07 PM
Strick's Avatar
Strick
Default Re: Changing gears (STL94LT1)
What was the hardest part of your gear change? Was it setting the tooth pattern?
Old Apr 29, 2003 | 01:10 PM
STL94LT1's Avatar
STL94LT1
I didn't do the gear change myself, left that to a proffesional. I paid $350 to have them do the complete job, pull the differential and set-up the gears. They did a great job, the 4.10's are quieter than the stock 3.45's.
Old Apr 29, 2003 | 01:18 PM
Strick's Avatar
Strick
Thanks for the info. Now to find a good dif guy in the Charlotte area that isn't booked for the NASCAR teams.
:flag :flag :flag
To Changing gears
