At What Point Will One Need Reprogramming?
Old Apr 29, 2003 | 02:02 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default At What Point Will One Need Reprogramming?
As the title says...at what point? The car is a 93 auto with Hooker LT's, no cats, Side Effects exhaust, cut lid with K&N. Also included is 3.75's though I don't beleive they matter.
Who knows?
BTW, I installed the LT's to the Side Effects without cats just today, they sound amazing :eek:
Eric
Old Apr 29, 2003 | 02:25 PM
drive it's Avatar
drive it
Default Re: At What Point Will One Need Reprogramming? (HOWSER)
We really need some scan data to say where you are now...if blms are hitting max limits-then you must reprogram. Also you really need to check it with a wideband O2 sensor to say where wot fuel/air ratio is at.
If the gear in the tranny is changed for the 3.75 then the speedo etc will read it no problem.
Old Apr 29, 2003 | 03:25 PM
vader86's Avatar
vader86
Usually, you have to have one every time you change the cam to something thats more than stock. A stock program can compensate for a cam thats very close to the stock specs, but not too far.
You shouldnt need a program yet, unless youre done with your mods.
Old Apr 29, 2003 | 08:58 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: At What Point Will One Need Reprogramming? (vader86)
Since you're a '93 with MAP, you'll benefit from a retune any time you make a significant change with bolt-ons, etc. MAP cars estimate fuel delivery based on a tabular model of an average factory-spec car.
The advantage of MAF cars, L98s included, is that the MAF / 02 sensor combo can compensate for mods up to the physical limits of the fuel delivery system. When it senses more air is available, it just orders more fuel to try to maintain stoichometric ratio.
Old Apr 30, 2003 | 01:06 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default Re: At What Point Will One Need Reprogramming? (Matt Black)
So who would be the best to use? Would an Ed Wright chip suffice? Also, can anybody estimate the power that I'd possibly gain from this??
Old Apr 30, 2003 | 10:32 PM
Wadoka's Avatar
Wadoka
I've only heard good things about Fastchips.
His website has an info request form where you tell him exactly what mods you've made, and he does the chip up based on what you tell him. That's still a guesstimate, of course. They're only changing the prom based on experience or manufacturer's represented data. You might have to change the chip a couple of times to dial it in.
Old May 1, 2003 | 03:20 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
The headers and no cats setup will allow the engine to breath a little better in the upper rpm ranges which will lean out the actual fuel air mixture. The aftermarket modified chips usually lean out the mixture in the upper rpm ranges to increase the power a bit which is what your mods will do so you shouldn't really need a chip change.
Save the chip changes until you go to bigger heads and/or cam.
Old May 1, 2003 | 07:02 AM
93 ragtop's Avatar
93 ragtop
The 92-93 LT1 are speed density instead of maf.
To At What Point Will One Need Reprogramming?
