Removing cat converter
Old Apr 29, 2003 | 02:15 PM
sprangsplaya's Avatar
sprangsplaya
3rd Gear
Default Removing cat converter
I heard this was illegal but if I removed it would it provide more horsepower for my 91.
Old Apr 29, 2003 | 03:16 PM
Bodhi's Avatar
Bodhi
Default Re: Removing cat converter (sprangsplaya)
Yeah 3 whole horsepower :crazy:
It's illegal and the fine is huge if you get caught.
Old Apr 29, 2003 | 09:04 PM
Rays91L98's Avatar
Rays91L98
Not that I ever would remove mine :D
But If Iwas to come across a cat converter delete pipe that bolted right in and could re-install the main cat for inspections. It sure would (speculation mind you) make a difference in performance, and sounds so much sweeter through the 40 series flowmasters on the back. :cool:
:seeya
Old Apr 29, 2003 | 10:16 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: Removing cat converter (Rays91L98)
:seeya
I've "heard" that a better way to do it is to have a piece of 3" pipe welded inside the converter housing. Bolt it back up and no one will ever know unless they do a sniff test.
Old Apr 29, 2003 | 11:10 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Default Re: Removing cat converter (flyersfan1088)
:seeya
They do a sniff test if you are pulled over for an infraction here in Fairfax if they have reason to believe you are running catless. Not worth the possible fines to me. I ran my 91 at different times with a clogged cat, hollowed cat and a Randon Technology cat. Big difference when i hollwoed the clogged cat. Almost no difference after installing a Random cat.
Guees you need to ask yourself, is it worth the extra 3HP? :leaving:
[Modified by ConeKLR, 11:13 PM 4/29/2003]
To Removing cat converter
