Just put on my Borla cat-back
Old Apr 29, 2003 | 05:29 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Just put on my Borla cat-back
I just went and had my Borla cat-back installed and after a year of muffler elims - it's a world of difference!!! I n the 5 blocks i drove back from the exhuast shop i could just feel the difference. throttle seems much more responsive and ready to go. the elims sounded great (maybe even better, I have yet to go WOT on the Borla) but they seriously affected my car's performance. Just a note to say how much of a difference there is... :cool:
now all i need are some new tips, those el-cheap-o sheet metal wrapped ones don't do it for me.... :cool:
[Modified by _freakmonkeydogboy_, 4:29 PM 4/29/2003]
Old Apr 29, 2003 | 10:00 PM
NE14SIN's Avatar
NE14SIN
Default Re: Just put on my Borla cat-back (_freakmonkeydogboy_)
Pictures don't work.
Old Apr 29, 2003 | 10:03 PM
RX7 KLR's Avatar
RX7 KLR
I have the Dyno sheets from my 89' that confirms your butt dyno feeling. I had elims for years, did a custom 3" catback with one Borla XR1, 4 hp and 18 lbs of tq more than the elims. :thumbs:
Old Apr 29, 2003 | 11:41 PM
Goody's Avatar
Goody
Default Re: Just put on my Borla cat-back (RX7 KLR)
Backpressure isn't always a bad thing.
Old Apr 30, 2003 | 05:31 AM
pablocruise's Avatar
pablocruise
There was a guy with a basically stock 89 at an auto-x a few weeks ago out this way. Except he had straight pipe to the borlas. They sound so loud and evil and powerful! I was really impressed! The car was fast too!
Can you tell if they are "straight-thru" design?
Old Apr 30, 2003 | 11:08 AM
_freakmonkeydogboy_
Default Re: Just put on my Borla cat-back (89 Paul in Cal)
it's not a straight-thru design, i have the entire cat-back, so it has a center resonator, but i think i will replace that w/ an x-pipe. would an x-pipe affect my back-pressure any, because right now it's a great thing :cool:
Old Apr 30, 2003 | 11:10 AM
_freakmonkeydogboy_
Default Re: Just put on my Borla cat-back (NE14SIN)
can everyone else see the pics? they aren't that good because of the lighting, but they should at least be showing up...i can see them :confused:
Old Apr 30, 2003 | 11:13 AM
Tourney3p0's Avatar
Tourney3p0
I can see it. It looks good.
Old Apr 30, 2003 | 11:14 AM
MrNuke's Avatar
MrNuke
Pics worked for me..
I wonder if I would gain back my little low-end loss if I changed form my 2 5/8 targa SS mufflers to a borla or so muffler design..I'm redoing my exhaust with headers and stuff soon anyways...
Old Apr 30, 2003 | 11:17 AM
_freakmonkeydogboy_
Default Re: Just put on my Borla cat-back (MrNuke)
i'm telling you, it's as different as night and day...you wouldn't be disappointed :D
Old Apr 30, 2003 | 12:58 PM
HammerDown's Avatar
HammerDown
The resonator is straight-thru, don't know about the mufflers though. Most people think the resonator is a bottleneck in the system, but really it is not. Just two pipes surrounded by some kind of sound dampening material. Kind of like a glass pack. Therefore, the x-pipe probably won't change your backpressure, but it might make your exhaust more resonant, ie more annoying drone.
Incidentally, I had muffler elims for 6 months, and then went to a 2-chamber Flowmaster, and it was night and day as far as throttle response is concerned. Much more response off the line, and more instant oomph whenever you punched it from a slow roll. If the motor is basically stock, then it is designed to run with some backpressure. Now, a heads and cam change is something totally different.
Old Apr 30, 2003 | 01:03 PM
VMAX451's Avatar
VMAX451
Default Re: Just put on my Borla cat-back (HammerDown)
The Borla mufflers are also of the "straight-thru" type, look in one end, see straight out the other. Just a perforated pipe surrounded by sound absorbent material.
Old Apr 30, 2003 | 01:05 PM
sundbergjc's Avatar
sundbergjc
Default Re: Just put on my Borla cat-back (Vince Ivanc)
And the total for this setup is about............what?
Old Apr 30, 2003 | 01:11 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
I have to differ I have the Borla XR-1 cat back connected to TPIS Longtube Headers and R/T High flow cats and removed the Borla Muffs and added the elliminators and the car actually sounds better and has run faster times at Englishtown...not much faster but a bit faster it could also be less weight from the mufflers being removed and the stock cats also being removed for the lighter pertier Random Tech cats .
[Modified by DINO, 12:14 PM 4/30/2003]
[Modified by DINO, 12:15 PM 4/30/2003]
Old Apr 30, 2003 | 01:40 PM
_freakmonkeydogboy_
Default Re: Just put on my Borla cat-back (sundbergjc)
i got the whole cat-back off eBay for $295
Old Apr 30, 2003 | 02:12 PM
Jstyle's Avatar
Jstyle
now thats lucky
Old Apr 30, 2003 | 03:22 PM
MrNuke's Avatar
MrNuke
They are??
So basically me change from the design I have now :
Mid America Targa style Stainless Steel mufflers 2.5"
(They are like glasspacks in reality. 4 nice SS 2.5" straight pipes
with internal perforated pipes...)
To a borla like or flowmaster like mufflers won't do anything?
Guess I could save the money then..
:D
To Just put on my Borla cat-back
Old Apr 30, 2003 | 03:26 PM
dgoodhue's Avatar
dgoodhue
A lot the targa mufflers I have seen are necked down quite a bit just before the tips and are quite restrictive, I don't know if your MA targa are like that though.
Old Apr 30, 2003 | 03:44 PM
VMAX451's Avatar
VMAX451
They are??
:D
From Borla's FAQ:
http://www.borla.com/faqs/?cartID=20030430121443146.122.142.10#13 ...
Q. Is our product different from a 'glasspack' design?
A. Yes. A glass pack is a muffler usually containing a cheap grade of loose fiberglass insulation in a louvered tube. ...<snip>... BORLA mufflers, on the other hand, contain T-304 Stainless Steel perforated pipe wrapped with several layers of Stainless Steel sound absorbing material and a blanket of ceramic sound absorbing, high temperature material. ...<snip>
They are essentially glasspacks. When I had mine you could look right through them. Flowmasters are completely different though.
Old Apr 30, 2003 | 08:15 PM
kittmaster's Avatar
kittmaster
Love my borlas too......good luck with em...... :thumbs:
