What tool do you guys use to pull codes?
Old Apr 30, 2003 | 03:24 AM
Light84vette's Avatar
Light84vette
Default What tool do you guys use to pull codes?
I have an 84, and lately its doing this Check Engine BS, I want to checkout whats wrong with it. I would just like to know if a company sells code readers of some sort? Thanks for the help :steering:
Old Apr 30, 2003 | 04:43 PM
Bluevette85's Avatar
Bluevette85
Default Re: What tool do you guys use to pull codes? (Light84vette)
Use a paper clip to jump terminals A+B of the ALDL link (upper right top row) and turn the ignition on but don't start the car. Your check engine light will flash 1.2,1.2,1.2, then flash the trouble codes stored followed by 1.2,1.2,1.2. Post these codes and we can tell you what they mean.
Old Apr 30, 2003 | 07:07 PM
Light84vette
Default Re: What tool do you guys use to pull codes? (Bluevette85)
I tried it, it flashed, but did not show any numbers. IS something wrong with the LCD? :confused:
Old Apr 30, 2003 | 07:52 PM
HighHopes85's Avatar
HighHopes85
It flashes Morse code style...not numbers...
One flash, pause, 2 flashes, pause = code 12
Old Apr 30, 2003 | 08:25 PM
kittmaster's Avatar
kittmaster
Gordon killebrews diagnotics jumpers
They can be found at http://www.gordonkillebrew.com
Kitt
Old Apr 30, 2003 | 10:18 PM
Light84vette
Default Re: What tool do you guys use to pull codes? (HighHopes85)
Okay I tried it out, the first 3 were exactly what you guys said and what the manual said, Flash, pause, thne two flashes.
After that happened 3 times their was another 4 quick flashes, no pauses inbetween, I think this happen 6 times, 1 set of 3? Anyway what does this mean? 4 flashes? :confused:
Old Apr 30, 2003 | 10:52 PM
Bluevette85
Sounds like you got a code 44. This means oxygen sensor lean. Could be a bad sensor, fuel pump problem, clogged fuel filter, clogged fuel injectors.
Old May 1, 2003 | 03:11 AM
Light84vette
Hmm, I changed the Fuel Filter recently, but the check engine light came on before I changed that out to, I plan on changing the O2 sensors tomorrow and see if it still checks out.
BUt how do you tell what codes it pulls? Say if their is a 5 flash, what would that be? A 55? How do you tell from pauses and flashes? Thanks for your help :yesnod:
Old May 1, 2003 | 01:24 PM
Joshua S. Smith's Avatar
Joshua S. Smith
I'm a huge supporter of the "paperclip" method myself.
Anyways, regarding the "pause" between the "flashes": lets just go with your "five" flashes. It will flash, short pause (bout one second), flash, short pause, flash, short pause, flash, short pause, flash. Then a little bit longer pause (bout two seconds). Then flash, short pause (bout one second), flash, short pause, flash, short pause, flash, short pause, flash. Now there will be a long pause (bout 5 seconds). This will tell you that is the end of this code. Hence code 55.
If there is more codes, they will come up the same way.
Hope this helps ya out a little bud. :)
Old May 1, 2003 | 06:46 PM
Light84vette
Default Re: What tool do you guys use to pull codes? (Joshua S. Smith)
Thanks for the help,
So if I got this right, say a 3flash occurs with a 4 sec pause after the code it done, then does that mean its a 34? :confused:
Old May 1, 2003 | 08:02 PM
Joshua S. Smith
No. The lentgh of the pause is not used as a "code number". If you get three flashes and then a 4 second pause, I would say that the four second pause is the pause that occurs to seperate the codes. The three flases shouldn't happen all at once. There might be one of those "two second" flashes in between somewhere.
Then it would turn out to be a flash-pause-flash-flash = 12, or a flash-flash-pause flash = 21.
Lemme type up a little diagram for you really quick:
Flash-pause-flash-flash = 12
Flash-pause-flash-flash-flash = 13
Flash-flash-pause-flash = 21
Flash-flash-pause-flash-flash = 22
Flash-flash-pause-flash-flash-flash = 23
Flash-flash-flash-pause-flash = 31
Flash-flash-flash-pause-flash-flash = 32
Flash-flash-flash-pause-flash-flash-flash = 33
I hope that I was able to make this a little easier for you to understand. I know that when I first started to read my codes, I had tons of trouble, but the people here helped me out drastically.
Also, I noticed in your signature, you live in Union City. I live about an hour away. If you want, I can meet you somewhere Friday evening or on Saturday to help ya out.
Old May 1, 2003 | 10:20 PM
Light84vette
Its cool, I think I got it, plus I wouldnt want to waste too much of your time for you to travel here and all. Anyway If their's ever a cruise or a Corvette show, please let me know, I want to come along to. :yesnod:
Old May 1, 2003 | 11:13 PM
Joshua S. Smith
Hay bud,
You ain't wastin my time. I'm just glad that you got it now. All I want to do is help out as much I can. Especially since I've been helped so much round here.
And... if there's any kinda cruise or get together in the area that I know of, I'll be sure to let ya know. One thing that might be going on, is a gettogether at the car museum in San Ramon. In case you interested. Here's the link: http://forums.corvetteforum.com/zerothread?id=538680
Take it easy bud. Hope the ocdes arn't to much trouble.
Old May 2, 2003 | 02:03 AM
Light84vette
HEy man,
I'll try to see if I can go down there or not, but its on a Saturday and I work that day, So I dunno :confused:
To What tool do you guys use to pull codes?
