EGR pipe gasket
Old Apr 30, 2003 | 05:41 PM
JCAIRE2's Avatar
JCAIRE2
Default EGR pipe gasket
Do I need to pick up a replacement when I change out my valvecovers? GM, or will autozone etc.. have it? Thanks :cheers:
Old Apr 30, 2003 | 05:50 PM
scorp508's Avatar
scorp508
Autozone will look at you like you are a freak on a leash. I tried to get them there and the guy didn't even understand the concept of an EGR Tube let alone the gaskets.
Hopefully you can reuse them, but if they are old enough they may split into a few layers when you take the tube off. GM should still have them available, but I don't have the P/N here.
Old Apr 30, 2003 | 06:42 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: (scorp508)
Thanks scorp, most appreciated. I'll call the parts department and see what they say. :cheers:
Old Apr 30, 2003 | 07:44 PM
honas's Avatar
honas
Default Re: EGR pipe gasket (JCAIRE2)
Just make one out of some high temp gasket material. It's a breeze.
Old Apr 30, 2003 | 08:44 PM
Vic'89's Avatar
Vic'89
Default Re: EGR pipe gasket (honas)
I purchased some new gaskets from Zip Products.
Vic
Old Apr 30, 2003 | 10:51 PM
86Pacecar's Avatar
86Pacecar
NAPA had one for mine.
Old May 1, 2003 | 08:46 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: EGR pipe gasket (86Pacecar)
Thanks guys :cheers:
To EGR pipe gasket
