ABS Problem, Need help asap.
Old Apr 30, 2003 | 07:22 PM
Jan2's Avatar
Jan2
Default ABS Problem, Need help asap.
Car is still in Virginia, after PCM failed last Friday, dealer is telling me that the right rear ABS Sensor needs replaced now, which comes as an assembly only including hub, part is $540. Looking at GM-AUTO-ARTS.COM the rear hub is $413 retail and the Speed Sensor is $45 retail and they can be ordered separate????
Is it required to replace the hub when you replace the ABS Speed sensor?
Any input will be welcome. I am 400 miles from the vette at this time.
Thanks JAN
[Modified by Jan2, 9:38 PM 4/30/2003]
Old Apr 30, 2003 | 08:52 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: ABS Problem, Need help asap. (Jan2)
That's a ripoff, you can get them anywhere from $150-$275 tops.
Call your local NAPA or try here www.contemporarycorvette.com
Old Apr 30, 2003 | 09:39 PM
Jan2's Avatar
Jan2
ttt
Old Apr 30, 2003 | 10:27 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: ABS Problem, Need help asap. (Mr Mojo)
Old Apr 30, 2003 | 10:50 PM
jfb's Avatar
jfb
The ABS sensor is replaceable all by itself. At least it was several years ago when my left rear sensor was replaced.
To ABS Problem, Need help asap.
