compresson test results
Old Apr 30, 2003 | 09:26 PM
SBNova's Avatar
SBNova
Default compresson test results
HELP !, I have a known poor condition 350 in my 85 L98 TPI. It is completely stock as far as I know. It smokes a little when it runs (at start-up, idle and cruise). So today I decided to do a compression test just to see which cylinders were bad. To my surprise, they all tested between 58 and 62 PSI while cranking. Now Ive never tested a stock smog type motor before but this seems very low! My 71 Nova 355 (which I know has a higher comp. ratio) checks at 180psi. By comparison I'd say the rings are all completely shot, BUT the rule of thumb is "as long as theyre within 10%(of each other)" which they are. Is this motor just that low compression and the stock cam limiting its cranking pressure THAT MUCH????
Old Apr 30, 2003 | 09:45 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: compresson test results (SBNova)
Hmm, doesn't sound right to me. My stock LT1 numbers were probably close to double that. There isn't THAT much difference between an LT1 and an L98 motor. I would say that you are loosing cylinder pressure somewhere.
What is very helpful is to do a leakdown test, it gives you a little more info than a compression test and you should be able to hear if it's leaking out the valves or around the rings. :cheers:
Old Apr 30, 2003 | 09:47 PM
CFI-EFI's Avatar
CFI-EFI
Assuming it was a proper test with all the plugs removed, throttle blades open, strong battery, etc. that is horribly low. My 1984, 150,000 mile, quart every 200 miles, wheezer, has compression from a low of 165 to a high of 175. Smoke at start up and jumping on the gas after deceleration, indicates leaking valve guides. Cruise and/or steady state oil burning points to rings. Mine is scheduled for replacement. I hope yours was a "bad" test. Good luck, and...
RACE ON!!!
Old Apr 30, 2003 | 09:57 PM
RX7 KLR's Avatar
RX7 KLR
I think it says on the shop manual anything below 140psi is dead. :nonod:
Old Apr 30, 2003 | 10:17 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: compresson test results (RX7 KLR)
How does it even outrun it's own shadow?! Those are hideous numbers. Time to rebuild. :cheers:
Old Apr 30, 2003 | 10:49 PM
SBNova's Avatar
SBNova
Default Re: compresson test results (flyersfan1088)
funny thing is- it really runs great! No comparison to my Nova of course, but it starts right up, idles and drives well! Seems peppy, but I drive a 400+ HP car every day, so a 230 whatever HP car just doesnt seem like much anyway. I think I'll try to check the calibration of my compression tester. 60 psi doesnt seem right to me either. Thanks for the replies
Old Apr 30, 2003 | 10:54 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Do yourself a favor and do a leakdown test...I did my compression about 5-8 times trying to figure out where my power went with my 350 and everytime it was ~160psi +/- 2 psi....Did the leakdown and knew in a about 15 minutes something was amiss. Pulled the engine apart and every top ring was busted in two. I will NEVER trust a compression check.
Old Apr 30, 2003 | 11:16 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I don't think that's even possible. I'd think with cylinder pressures that low, the gas would never burn, or burn all the way. It definitely would not run well, if at all. Have you tried again with another guage or spark plug hole fitting? If the numbers are that low and consistent, it almost seems like a rebuild gone wrong, or maybe cam timing being wayyy off. It just seems doubtful that broken rings would still be that consistent.
You did pull all the plugs and turn the motor with the starter right?
I had between 180 and 190 psi on my stock '85. As the engine cooled, the numbers dropped noticeably, (I did three tests)
Old May 1, 2003 | 01:45 AM
StealDads67's Avatar
StealDads67
Default Re: compresson test results (ski_dwn_it)
:iagree: Doing the compression test doesnt hurt.... but i dont find it that useful unless you do a leakdown test.
To compresson test results
