should my dist. move easy!!!
Old May 1, 2003 | 07:30 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default should my dist. move easy!!!
i know it shouldnt but i can turn my cap pretty easy and im sure it moving the dist. but can the cap it self move kinda dumb question but i was wandering :confused: :_dupe:
Old May 1, 2003 | 07:49 PM
1MoorTym's Avatar
1MoorTym
Default Re: should my dist. move easy!!! (jparr)
um, no. The cap is either screwed down or clamped. After checking that, your timing is probably way out so check that as well and then tighten that hold down bolt.
Unless this is a joke in which case you got me :D
Old May 1, 2003 | 08:11 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: should my dist. move easy!!! (1MoorTym)
:iagree: How does it run? If it does?
Hope this isn't a trick question :rolleyes:
:seeya
:steering:
Old May 1, 2003 | 08:13 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
no joke i was jus curious i can turn my cap forward and back i was jus wanting to make sure that when the cap moved it also moved my dist!!!! a freiend told me it should move some but i was thinking that it and the dist where both screwed down together. i better tighten my nut up then :thumbs:
JAY
Old May 1, 2003 | 08:18 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: Your friend may be as old as me and remember the days when distributors had an external vacuum advance and did move :D
But nowadays, these newfangled gizmos shouldn't move at all!!!!!
:steering:
Old May 1, 2003 | 10:07 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: should my dist. move easy!!! (jackdaroofer)
No move, be sure to unplug the ESC before setting the timing. Set it to 6* base. Then unhook your battery, plug the esc back together, hook the battery up and all should be fine. :cheers:
To should my dist. move easy!!!
