New style heads
Old May 2, 2003 | 12:09 AM
black85vette's Avatar
black85vette
Default New style heads
Im considering using some new style heads that dont have the ports for the egr, what has to be done to the system to delete it. What im getting at is if the only thing I do is just bolt the intake back on and hook every thing back up the way it was ,will the computer throw a code ?
Old May 2, 2003 | 01:37 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: New style heads (black85vette)
Though I've not done it, the ECM should throd a code.
Check out EGR explanation and a potential fix in case you get the code.
Old May 2, 2003 | 11:26 AM
Curveit's Avatar
Curveit
My '86 has the alum. heads w/out EGR. It has a 3/4" tube from the #8 header pipe to the EGR, if this helps.
:chevy
Old May 2, 2003 | 12:50 PM
black85vette
Default Re: New style heads (Curveit)
Im sorry I didnt explain very well it is an 85' so the egr is a internal part of the intake fed through the heat riser port in the head. I noticed that there is a sensor near the egr valve.
Old May 8, 2003 | 11:44 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I'd go for the Edelbrock Aluminum heads......proven to get the best HP....increase.....and a good price.....
So what are you going to do???????????? Let us know....OK?????
thanks
tony
:flag
Old May 9, 2003 | 01:11 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: New style heads (oldace84)
I blocked off my EGR, capping all associated vacuum lines and leaving all electrical connections attached. Doing this makes the computer think everything is working correctly (the EGR solenoid still trips, but there are no vacuum lines connected to it and the EGR is blocked so it doesn't flow any air, but the computer thinks it is. ECM's are dumber than you think they are. You let it think the EGR is attached and working when the important air connections are disconnected and it has no way of knowing that no EGR is getting into the manifold.
What you'll want to do is make a block-off plate for the port in the intake manifold where the tube connecting the exhaust manifold and intake manifold goes, disconnect the vacuum line going from the EGR solenoid (under the TB) to the EGR valve, and re-route the vacuum line which goes from the vacuum canister to the EGR solenoid to the port on the bottom of the TB. Leave the electrical plug going into the EGR solenoid in place, and the ECM won't trip codes but your EGR is now completely disconnected.
Old May 9, 2003 | 10:54 PM
black85vette
Default Re: New style heads (CorvetteZ51Racer)
I decided to go with the Pro topline cast iron heads they have egr ports so they will work. Just curious but If you disconnect the egr valve vac line it should not open, so blocking off the ports has no benifit other than weight.
Old May 10, 2003 | 06:05 AM
mountainmotor's Avatar
mountainmotor
Just a tip if you bought the bare Pro Torkers. Although they advertise them to use 1.94 - 1.5 valves they actually use the 2.02 - 1.6
Never mind the post if you bought assembled larger heads like the 180's and up
To New style heads
