Corsa - still the best?
Old May 2, 2003 | 01:45 AM
2dogs's Avatar
2dogs
Default Corsa - still the best?
Been focused on the other toys for awhile....
Still want a great exhaust. Is Corsa still it? Who has the best deals? (96 LT1)
Thanks,
Dave
Old May 2, 2003 | 07:35 AM
GS345's Avatar
GS345
St. Jude Donor '11
Default Re: Corsa - still the best? (2dogs)
Power Effects.....I think there the best :yesnod:
:cheers:
jeff
Old May 2, 2003 | 08:51 AM
Nathan Plemons's Avatar
Nathan Plemons
If you want to spend $900 on an exhaust system then go for it. I'll admit that it's a pretty system but I can't justify the price. I honestly don't think they sound all that great either.
I run flowmasters and they are obviously not for everybody but the fact is there are plenty of exhaust systems out there that perform just as well and cost a lot less. I would encourage you to ride in as many different cars as you can before you make the decision that Corsa is the best. I honestly wanted the Corsa exhaust fore my Vette before I ever had a Vette. I thought it was the best because everybody raved about it. I decided to buy the flowmasters due to cost and I couldn't be happier.
IMHO Corsa is kidna a cult, kinda like Hurst (can't talk I belong to B&M cult), and Zaino (can't talk there either, I'm a member of that cult)
A year or so ago I went to a ZR-1 gathering and I'd say over half of the cars there had Corsa exhaust. They didn't really sound THAT good and it kinda made me sick, much like that car show I went to in which EVERYBODY had torque thrust wheels. As soon as everybody has the same thing the effect kinda goes away.
Remember, buy a Corsa exhaust and be unique, JUST LIKE EVERYBODY ELSE.
In the long run you've gotta do what makes ya happy :cheers:
Old May 2, 2003 | 09:01 AM
Cal Vette's Avatar
Cal Vette
:iagree: For performance and looks, I feel they are the best out there. I get alot of compliments on mine. :D
Old May 2, 2003 | 10:11 AM
SouthernSon's Avatar
SouthernSon
I like the corsa's. There is a reason they are so popular. If I want to hear the engine, I put it in 5th on the interstate. To quieten it completely, I put into 6th (overdrive). Of course the Hot Cam makes it sound a little nicer in my opinion, too.
I found the corsas for $745 in a promotional price break from a vendor down in Tx. a year or so ago. Don't really remember the name of the place.
Old May 2, 2003 | 10:34 AM
bogus's Avatar
bogus
Default Re: Corsa - still the best? (southern_son)
The Corsa is a quality piece.
I like it for the exact reason mentioned above. If you wanna hear it, you can, if not, you won't.
If you do a lot of highway driving or use your vette as your daily driver, you will want Corsa's.
The advantage to the Corsa system is the removal of exhaust resonance. And beleive me - its the only system I have heard that has removed it completely.
At 1800rpm in 6th gear, all you hear is tire rumble, engine mechanicals and a bit of wind noise... but little exhaust echo.
That alone is worth the price.
Old May 2, 2003 | 10:40 AM
BaseballDude's Avatar
BaseballDude
Default Re: Corsa - still the best? (bogus)
The Corsa is a quality piece......If you do a lot of highway driving or use your vette as your daily driver, you will want Corsa's.
:iagree:
Old May 2, 2003 | 10:56 AM
Glasman66's Avatar
Glasman66
If it about fit and finish and resonance go with the Corsas.
If it is about money go with the eliminators.(Have a muffler shop cut and weld some straight pipes on)
I love the way both sound.
Old May 2, 2003 | 11:18 AM
Crispyc21's Avatar
Crispyc21
C4 = Corsas
C5 = Borlas
Old May 2, 2003 | 11:22 AM
scorp508's Avatar
scorp508
In my opinion..... never were to begin with.
Old May 2, 2003 | 11:30 AM
No Go's Avatar
No Go
I gained 17 RWHP off of a Corsa install on my LT4 (back to back dyno test)
I don't know of any other exhaust that can do that...
Near silence on highway is big bonus for me...
By the way, a ZR1 Corsa sounds much different and louder than the LT1/4 type.
Old May 2, 2003 | 11:38 AM
John Row's Avatar
John Row
No, but that never stopped anyone from buying them.:D
That is my totally unbiased objective opinion......... Note SIG.
[Modified by John Row, 10:40 AM 5/2/2003]
Old May 2, 2003 | 01:22 PM
dscottr's Avatar
dscottr
Default Re: Corsa - still the best? (John Row)
I have no complaints with the sound of Corsa system, and before headers the resonance would disappear completely in o/d on the highway.
But as nice as the tips look when new, they will never look like that again. The 2 inside tips get black buildup that no amount of cleaning will restore.
Personally, I am thinking of changing mufflers with a different style tip, so that the black carbon build up will not show so much.
Old May 2, 2003 | 01:31 PM
tuband's Avatar
tuband
Cruise-In I Veteran
I have Corsas and Borlas. I've also had stock as well as muffler eliminators. All are good and have a place in the Corvette world. You've received much good advice in this thread but perhaps the best discussion on the issue was by Nathan Plemons ... and he is absolutely right that you should listen to as many as possible and ride in the cars as well. Then pick the set up YOU like. You'll never regret it. Good luck.
Old May 2, 2003 | 02:25 PM
bogus's Avatar
bogus
Default Re: Corsa - still the best? (dscottr)
if you change the muffler, you screw the entire design of the corsa's.
they use a sound cancellation system. at low rpm, the sound goes into the chamber and gets bounced around. as the sound comes forward, it negates the sound going back. works kinda like an expansion tank on a 2 stroke.
the inner tips do all the work, the outer tip is the pressure release for the sound canceling chamber.
at full throttle, the exhaust blasts straight through to the inner tip.
Old May 2, 2003 | 02:26 PM
VMAX451's Avatar
VMAX451
I've had several different systems on my LT1 and L98, and the Corsa is far and away the best in terms of quality and fit, not to mention lack of resonance. No contest. Anyone can bend pipes and weld tips to mufflers, Corsa actually did some acoustical engineering when designing the system, which is important if you don't like skull crushing resonance.
Old May 2, 2003 | 03:47 PM
Steve'95's Avatar
Steve'95
I have my Corsa system on order right now with TBYRNE Motorsports. They charge $759.99. This is the best price I've found so I jumped on it. They have a web site and you can call them at 877 482-9763.
To Corsa - still the best?
Old May 2, 2003 | 04:28 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
The Corsa system's fit and finish is phenomenal, and in my opinion the tips look awesome. Yes they are a pain to keep clean but I think it's worth it. Some people may not like the sound, but I do, and I don't regret dropping the $750. They are a little on the quiet side, however I've heard a C4 at a car show that had them with headers, damn it sounded nice (IMHO)
Drew
Old May 2, 2003 | 06:00 PM
CNTDRV55's Avatar
CNTDRV55
Default Re: Corsa - still the best? (BaseballDude)
:iagree:
:iagree:
Old May 2, 2003 | 06:05 PM
dizwiz24's Avatar
dizwiz24
Default Re: Corsa - still the best? (tailgunner)
I would be part of the club if the Corsa was lighter. If any of you have ever removed your stock exhaust, you know its heavy...especially the mufflers.
I dont know why Corsa didnt make a titanium exhaust for the C4 like they do for the C5. Guess they figure C4's are dead, and its not worth the investment.
