Valve seals, springs ...
Old May 2, 2003 | 01:39 PM
Sliding's Avatar
Sliding
Default Valve seals, springs ...
I've got a few questions. Below are pictures of my valve springs and seals.
On pic you can see that springs are dual; do you also have stock dual springs?
Also I saw that when ordering valve seals they are always sold in set of 16, but I only had seals on intake valves :confused:
What are this little plastic shims that were on valves :confused:
I had to brake them to get the valves out of valve guides.
Do I have to order these also or what?
:confused: :confused: :confused:
[Modified by Sliding, 8:05 PM 5/2/2003]
Old May 2, 2003 | 01:46 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Default Re: Valve seals, springs ... (Sliding)
You should have dual springs. Dual springs are a performance spring that they handle high rpm's and withstand hard driving. The one piece in your photo that looks like a cup is a "Umbrella" This works like a seal. The other piece is a valve seal. I know that when I replaced mine a few months ago, The small seal that looks like a O ring where just breaking off. I am not sure if this is what you where considering a "Shim". This is the only part that I could think of that would break when removing. When you install all the new seals, Put oil on them. They slide on easier. Good Luck.
Old May 2, 2003 | 01:50 PM
Sliding's Avatar
Sliding
Default Re: Valve seals, springs ... (89NYFINESTVETTE)
I must say that it looks differently on most european engines.
Thanks, it's much clearer now.
Can I order this "Umbrella's" as a spare part?
I didn't see it anywhere.
Old May 2, 2003 | 01:58 PM
VQT88Vette's Avatar
VQT88Vette
I had to order the umbrellas as the separate order. When I order the seals for mine they only came in with the O-rings and the bottom seals, not the Umbrellas seals. Since I need to put things back together that weekend, I found out the local auto part store has them. I don't know if you have that kind of luck.
To Valve seals, springs ...
