AC gremlin
Old May 2, 2003 | 04:19 PM
buzzbomb's Avatar
buzzbomb
Default AC gremlin
My AC quit working on the '84. There should be a wire running between the pressure cutt-off, and the cycling switch. If I jumper these two switches together, everything works. Does anyone know where the wire goes, and if it has a connector somewhere along it, that could be the source of the problem? :smash: :confused:
Old May 2, 2003 | 06:53 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: AC gremlin (buzzbomb)
Buzzbomb,
If you think you have a gremlin, take a look at this one!
http://cgi.ebay.com/ebaymotors/ws/eB...&category=5357
Sorry I couldn' resist, :rofl: :lolg: :lolg: :rofl: That almost made me **** my pants when I saw it.......
Unfortunately, I don't have an answer to your question eiher, but here is a bump to the top, so your a little more visable :cheers:
Old May 2, 2003 | 09:20 PM
buzzbomb's Avatar
buzzbomb
Default Re: AC gremlin (ski_dwn_it)
Looks like it would solve my AC problems, maybe I'll put in a bid! :cool:
Old May 3, 2003 | 01:05 PM
SunCr's Avatar
SunCr
Wires are spliced to provide a ground path through the high pressure switch, then to the lower pressure switch & then to the frame for a/c clutch operation. Splice should be in a 1/4 or 1/8 inch loom following the high pressure line, so it should be somewhat easy to find. May have melted if it contacted the header. Lead is from dash assembly, I believe out from the front harness connector behind the battery.
To AC gremlin
