Interior engine compartment Heat!
Old May 2, 2003 | 08:05 PM
nopain1984's Avatar
nopain1984
Default Interior engine compartment Heat!
I am running a 383 with Tpis headers(ceramic coated).Coolant temps are fine(evans cooling)But engine compartment is hot!Breathers are poping out(seals are melting).Does any one have those interior side fans that corvette central used to sell?Who makes them?Do not want to go to a cowl induction hood. :chevy
Old May 2, 2003 | 11:22 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Interior engine compartment Heat! (nopain1984)
Are you sure you timing is not retarded? I have the same setup - 383 TPIS headers and I originally had problems with heat until a friend timed it correctly.
Old May 9, 2003 | 12:00 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Do you have the stock or reworked CrossFire Set-up????
The stock hood can be set up for ram air.....
Go to the CrossFire Forum........It should help you...
I'm sorry that I don't know the URL......Maybe someone can chime in and give you the info....unless you already know it......
Good Luck
tony
:cheers:
Old May 9, 2003 | 02:29 AM
drive it's Avatar
drive it
I ended up using the hood louvers (functional!) from here-www.greenwoodvette.com/options.htm
To Interior engine compartment Heat!
