MSD Ignition Box installation question?
Old May 3, 2003 | 01:41 AM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Default MSD Ignition Box installation question?
92-96 C4 Ownwers with MSD ignition boxes how did you tap into the battery for positive and negative ground?
Thanks,Michael
:cheers:
Old May 3, 2003 | 08:16 AM
kittmaster's Avatar
kittmaster
Default Re: MSD Ignition Box installation question? (meyre1)
You can get a GM battery post extender....it has a main bolt for the main car battery and an added bolt built in to add other components......these are cheap usually 5 bucks per post..........get them at any car audio shop........good luck
Kitt
Old May 3, 2003 | 11:37 AM
Nathan Plemons's Avatar
Nathan Plemons
I went for the positive block located directly behind the battery.
Old May 3, 2003 | 11:59 AM
cprgmr's Avatar
cprgmr
Thanks,Michael
:cheers:
I installed the MSD up by the passenger side headlight, so I had to extend the MSD wires themselves. I picked up some wire tubing, and eyelet connectors big enough to fit around the stock +/- cable ends that attach to the battery itself. :)
Old May 4, 2003 | 05:17 AM
gcrouse's Avatar
gcrouse
I have my MSD on the pass side firewall brace. Ran positive straight up from the starter; drilled a hole in the hood release bracket for grounding.
To MSD Ignition Box installation question?
