heated O2 censor ( again )..
Old May 3, 2003 | 02:19 PM
devilfish's Avatar
devilfish
Default heated O2 censor ( again )..
could you tell me what other car is using the "heated O2 censor" ( autozone part number 13190 ) ? Im looking for the bosh partnumber for it, or what other car that use it.
Old May 3, 2003 | 03:51 PM
devilfish's Avatar
devilfish
Default Re: heated O2 censor ( again ).. (devilfish)
can i use any 3 wire bosh unit??
Old May 3, 2003 | 05:20 PM
HighHopes85's Avatar
HighHopes85
(autozone part number 13190 ) ? Im looking for the bosh partnumber for it, or what other car that use it.
13190 is the Bosch part number (this is the number the Bosch catalog will show, assuming that number exists)...not just the AZ lookup number. There are a gazillion 3 wire O2 sensors you can theoretically use. The differences are in the 1) Length of harness and 2) Style of connector. Possibly shell design comes into play--been a while since I looked in depth.
FWIW, PepBoys sells the correct connector for some of the Bosch 3 wire O2s. It is just going to be a generic 3-pin weatherpack connector, but it has the correct "key" on the male plastic housing.
Ask your local AZ to see their Bosch catalog (if there is a store near you). You can look up to see what wire length and connector you want and then go from there. Kinda like building your own O2 sensor.
Old May 3, 2003 | 05:24 PM
devilfish's Avatar
devilfish
Default Re: heated O2 censor (HighHopes85)
i really dont care about the cabel lenth, cause I can solve that with extentions.
I just cut the wires.
How about the thread size etc, is that the same on all the o2?
ANd what about the 3 cabels, are them labeld with +/- etc?
thanks
Old May 3, 2003 | 05:32 PM
HighHopes85
Default Re: heated O2 censor (devilfish)
Hook one white to ground, one to ignition feed (or a ign. powered relay) and the black to the sensor. Use butt splices (don't solder the wires). Shell design/thread is what I meant...I think I have seen some with different threads on some weird apps, maybe some standard apps too.
FWIW, there are about 2 threads on heated sensors a week. A search in the archives will help you out a bunch.
Old May 3, 2003 | 07:05 PM
devilfish's Avatar
devilfish
belive me I did my search, but i still got some questions. I hope you can guide me...
First..
Do you know any vehicle that has a heated O2 stock? Im thougt you mayby could try a used one?
second..
I noticed that bosch has 3 kind of O2, 1 wire,3 wire and 4 wire? Is all the 3 wire heated O2?
And ( this could be hard to answer ) is it the same bolt pattern on all O2 cenors?
Thank you
Old May 3, 2003 | 07:26 PM
VMAX451's Avatar
VMAX451
I think the later LT1/LT4 vette's used heated O2's stock, not sure what year though. My '92 manual shows that ZR1's used heated O2's that year, but LT1's did not.
Yes, 3 and 4 wire are heated. The difference between them is that the 4 wire has an extra wire for the sensor ground, whereas the three wire relies on grounding through the exhaust system to chassis. The heater circuit is two wires in both cases, power and ground.
A parts guy told me they're all the same, but I wouldn't believe it unless I verified it myself, fwiw.
To heated O2 censor ( again )..
