L98 Intake Porting Questions...
Old May 3, 2003 | 09:05 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Default L98 Intake Porting Questions...
A couple of questions... On a stock L98 engine, what kind of performance numbers can I expect from porting/polishing my intake, including plenum, runners and intake base? Also will I then need to move up to a 52 or 58 mm TB? What will the addition of the new TB do? Thanks for the input.
Old May 3, 2003 | 09:16 PM
ZD1's Avatar
ZD1
Default Re: L98 Intake Porting Questions... (Blueyednd)
expertly and fully porting the manifold base will result in 7-12 HP (see ligenfelter's website) Best cost effective thing to do is to chunk the whole thing. Moving to a 52mm TB will also imporve hp by a few. These mods really strive for/work for motor that have the "full package"-whatever that means to you.
Old May 3, 2003 | 11:20 PM
h rocks's Avatar
h rocks
Not worth the time and effort. Adding a 52mm TB is especially a waste. The base and runners are super restrictive. There's usually an intake setup floating around the "for sale" section that's not too outrageously priced.
Old May 4, 2003 | 11:13 AM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Thanks for the quick replies!
Old May 4, 2003 | 06:06 PM
Vic'89's Avatar
Vic'89
Porting a stock lower intake will provide very little gains.
Vic
Old May 5, 2003 | 06:37 AM
pablocruise's Avatar
pablocruise
on my 355, I switched from stock 48mm to a 58mm one day. With no other changes(both TPS set to .50v) I immediately lost smooth/soft throttle response. Since more air was travelling past the blades, higher revs and more power. Got old real quick.
Old May 5, 2003 | 01:00 PM
Aaron's 87's Avatar
Aaron's 87
Default Re: L98 Intake Porting Questions... (Vic'89)
Porting the plenum, base, and runners can significantly increase their potential - do you have the heads, cam, and exhaust to take advantage. If you are going to spend money on the porting, save it and buy a better intake setup when the car needs it.
Old May 5, 2003 | 01:30 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
I wont know what kind of gains the TPI porting gave me b/c I did many other mods at the same time. The only thing that would show on a dyno is how many more RPM I gained. In stock form, the HP died off just shy of 4400 rpm's. I might have gained 3 or 400 more RPM but I won't really know until I do some trans work and get it on a dyno and I won't be able to dyno for a while. :(
To L98 Intake Porting Questions...
