ATF change 700R4
Old May 4, 2003 | 03:38 PM
C10 JDR's Avatar
C10 JDR
Default ATF change 700R4
My trans fluid is brown and smelly. So I have dropped the pan (makes great hair gel), and drained the trans. How do I get the stuff out of the converter, or does it stay there or what? This car is new to me, it could be the opriginal fluid for all I know (86000 miles). Any recomendations on fluid?
Old May 4, 2003 | 05:14 PM
myscx's Avatar
myscx
Default Re: ATF change 700R4 (britvette)
Mobil 1 ATF :thumbs:
Old May 4, 2003 | 08:16 PM
C10 JDR's Avatar
C10 JDR
Default Re: ATF change 700R4 (myscx)
Thanks for that, but what about getting the old fluid out?
Should I put some cheap stuff in , let it slosh around for awhile then go to Mobil 1 - or.......?
[Modified by britvette, 2:17 AM 5/5/2003]
Old May 4, 2003 | 08:25 PM
johncazin's Avatar
johncazin
tought to get it all out without dropping the torque converter, but I get a fair amount out by unhooking the cooler lines at the radiator, and idling the car a couple mins.
Old May 4, 2003 | 08:33 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: Search the archives, there are probably more posts on this subject than any other.
In short, disconnect the hose at the RAD, put the discharge (flow to RAD )hose in a bucket to catch the old fluid.
Add and keep adding lots of new fluid as a friend starts and stops the engine to be sure the tranny doesn't run out. Will take 13+ quarts
:D :steering:
[Modified by jackdaroofer, 8:33 PM 5/4/2003]
Old May 4, 2003 | 08:52 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: ATF change 700R4 (johncazin)
:iagree: and add new fluid in at the same rate it's being pumped out :cheers:
Old May 5, 2003 | 07:50 AM
C10 JDR's Avatar
C10 JDR
Thanks for your replies, I will take your advice
:cheers:
To ATF change 700R4
