1985 steering rack setup?
Old May 4, 2003 | 09:56 PM
Detroit Vette's Avatar
Detroit Vette
Default 1985 steering rack setup?
Can someone tell me if these racks have any adjustment? The one i have has more stroke on one side then the other :confused:
Old May 5, 2003 | 02:00 PM
OnDVirg's Avatar
OnDVirg
Default Re: 1985 steering rack setup? (sdixon)
It sounds like the rack wasn't "centered" before a former front-end alignment. If the wheel is turned either to the left or right when the toe is adjusted, you can end up with more travel on one side and less on the other.
The only way to fix is to have it aligned and make sure that equal amounts of travel are on both ends before the toe is adjusted.
Old May 5, 2003 | 02:31 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: 1985 steering rack setup? (OnDVirg)
:iagree: If it's off by a significant amount then someone may have installed the ragjoint and coupler 180 degrees off. Most likely it just wasn't centered before aligning.
To 1985 steering rack setup?
