Shift Kit installed - Reverse is back
May 5, 2003 | 03:43 AM
http://forums.corvetteforum.com/zerothread?id=520592
Problem solved.
It was the regulator valve that was causing the reverse problem. I didn't install it correct, the lock ring was in a wrong position.
Just wanted to tell you the good news.
:cheers:
May 5, 2003 | 08:32 AM
Re: Shift Kit installed - Reverse is back (Cratzy)
Tell me more about your shift kit.... Do you get good positive shifts now? What kit did you use... Was it hard to install (beside the little problem)?
:flag :steering: :chevy
May 5, 2003 | 08:58 AM
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
:hurray:
May 5, 2003 | 11:27 AM
Did exactly the same thing two weeks ago.
It looks like that snap ring goes in, but it's supposed to go in way further up, with only 1/16" of travel for the boost valve.
It's a tough one to work with and get right, huh?
May 5, 2003 | 11:34 AM
Re: Shift Kit installed - Reverse is back (shansen)
I feel the transgo video doen't put enough emphasis on TV Valve snap ring. Its a rookie mistake a that a lot of first timers miss...
May 5, 2003 | 11:19 PM
Re: Shift Kit installed - Reverse is back (dgoodhue)
Is that the vertical valve in front of the valve body? I took me two hours to figure it out...glad I'm not alone.
Eric
May 7, 2003 | 05:40 AM
Re: Shift Kit installed - Reverse is back (silver & red CE)
Eric
Yes, that is the one. It should say something about it in the manual since it seems like it is a common mistake to do what I did.
It now shift good and firm, just the way I wanted it to do. :D
