Alignment ?
Old May 5, 2003 | 04:28 PM
ROADAPPLE's Avatar
ROADAPPLE
Default Alignment ?
Vette Brakes & Prod. suggests:
FRONT
Toe : 1/32" in
Camber : 0 neg.
Caster : 5 - 7 pos.
REAR
Toe : 1/8 in
Camber - 0
for a daily driver. Is this a "better" setting than the factory settings.
I know "better" is highly subjective, what I am looking for is a setting that does not "hunt" in the truck ruts. and is not darty.
I am hesetant to go to an alignment shop with my own settings (VP&P suggestions) just to find out that the car is squirlly, and then go back to the shop and look like a dweeb and ask them to align it to factory specs.
Hasve you used these settings? Will my wife squack when she drives the car with these settings? Or should I just stick with the factory settings?
Thanks,
Old May 5, 2003 | 06:39 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Alignment ? (C44ever)
Just go to Firestone and pay to have the lifetime alignment done. If you do not like it just go to another Firestone and have them change it back. ;)
Old May 5, 2003 | 08:53 PM
R23HTC's Avatar
R23HTC
Default Re: Alignment ? (Vette92)
Here's the specs that were posted in Corvette Fever a few years back. As Vette92 stated, get the lifetime at Firestone and you can change it if you don't like them.
Click the pics for full size. At full size you should be able to read everything.
Old May 5, 2003 | 08:54 PM
R23HTC's Avatar
R23HTC
Default Re: Alignment ? (R94 LT 1)
BTW, for what it's worth, I think I'm going with the Advanced Street setup when I get mine redone. I think that may be what you're looking for as well.
To Alignment ?
