where did you put it?
Old May 5, 2003 | 06:14 PM
devilfish's Avatar
devilfish
Default where did you put it?
the 12v feed to the heated O2 censor? I whas thinking to piggy back the wiper cabel? Give me some ides
THanks
Old May 6, 2003 | 01:58 AM
drive it's Avatar
drive it
Default Re: where did you put it? (devilfish)
I tapped the fan relay for it.
Old May 6, 2003 | 12:03 PM
Nathan Plemons's Avatar
Nathan Plemons
I found the signal wire for the fuel pump relay coming out of the ECM and tapped it. I chose it because it only comes on for a second when you just turn the key on and then goes off. I didn't want them on all the time the car was just ON, draining my battery even faster.
I used another relay to run power through a fuse directly from the battery, no sense in putting extra load on an existing circuit.
Old May 6, 2003 | 02:29 PM
devilfish's Avatar
devilfish
Default Re: where did you put it? (Nathan Plemons)
what cabel on the fan realy. And where is it located?
Old May 6, 2003 | 05:38 PM
devilfish's Avatar
devilfish
Default Re: where did you put it? (drive it)
tt
To where did you put it?
