4.09 with a automatic
Old May 6, 2003 | 07:18 PM
93 ragtop's Avatar
93 ragtop
Default 4.09 with a automatic
Anybody doing this? I purchased a dana 44 conversion with a 4.09 installed. Just wondering if anyone is doing this and also were you able to get your speedo. accurate.
Old May 6, 2003 | 07:43 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: 4.09 with a automatic (93 ragtop)
Talk to Mackey, he's running a 4.09, at first he started running a taller tire, but he's back to the 26".
Actually I just realized, you have a '93, so you would need the speedo gears, Mackey was able to reprogram for his.
Old May 6, 2003 | 10:21 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: 4.09 with a automatic (Mr Mojo)
I think it really depends on your engine....I personally think that is WAY WAY to steep for a 700r4 tranny. That will put your ratio at 12.45! That is STEEP. If you plan on burning up the tires its great, but I think hookin is gonna be a MAJOR problem.
The rule of thumb is a really powerful engine only needs ~9.00 gear ratio, where a weak low power engine can benefit from a steep gear ~12.00 gear ratio.
We are able to run 3.07 gears and get awesome 60' times and good ETs as well. I think the biggest mistake guys make is going to steep with gears. It makes power band shorter/quicker and makes hookin tough.
Just my .02 :cheers:
Old May 6, 2003 | 10:31 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: 4.09 with a automatic (ski_dwn_it)
Not to mention elevated cruise rpms. This may or may not be of concern to you. 4.09:1 is too low for MY tastes but it may work great in your circumstances. Good luck, and...
RACE ON!!!
Old May 7, 2003 | 10:06 AM
DRAGRACR's Avatar
DRAGRACR
I've got 4.30's in mine. :eek: :yesnod: You can change the transmission gears for the speedo, or you can buy one of the electronic converters for around $150.
Old May 8, 2003 | 07:17 AM
93 ragtop's Avatar
93 ragtop
Default Re: 4.09 with a automatic (DRAGRACR)
Well, thanks to everyone for answering. Actually I wanted a 3.73, but I got a good deal on this one. And it is supposed to have a hardened pin from toms differential installed as well. I have not had any problems with the dana 36, which is currently in the vette, but I want to try drag radials and a line lock. My luck it would break first time.
Old May 8, 2003 | 09:50 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
my combo works fine for me but the racer in me really wants 5.13 and a 30" tire.
Old May 8, 2003 | 11:23 PM
ScottsLS3's Avatar
ScottsLS3
Default Re: 4.09 with a automatic (mackeyred96)
What did you pay for this 44?
Old May 9, 2003 | 06:30 AM
93 ragtop's Avatar
93 ragtop
Default Re: 4.09 with a automatic (ScottsLT1)
I paid 1400 for the conversion. That includes the support beam, driveshaft, batwing, and diff.
Old May 22, 2003 | 09:33 PM
mackeyred96
I got my converison from "NOT JUST VETTES" got everything including new posi, all gears, and new case. About $2100. and well worth it for what I got.
Old May 23, 2003 | 02:56 AM
ScottsLS3's Avatar
ScottsLS3
Son of a B ...i need some gears :banghead: :banghead: :banghead: :banghead:
Old May 23, 2003 | 03:14 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Wow....Steep!!!!!!!!!!!!
But to each his own.....
Good luck...
tony
:cheers: :smash: :cheers:
To 4.09 with a automatic
