Fuel Pressure Regulator Vacuum Question...
Old May 6, 2003 | 09:57 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Default Fuel Pressure Regulator Vacuum Question...
There is a tech tip here that talks about removing the vacuum line from the fuel pressure regulator for more HP. Anyone tried it? Does it work? Pro/Cons? Thanks...
Old May 6, 2003 | 10:10 PM
sumoboy's Avatar
sumoboy
Default Re: Fuel Pressure Regulator Vacuum Question... (Blueyednd)
Not really worth it......just buy a AFPR.
Old May 6, 2003 | 10:13 PM
Siveck's Avatar
Siveck
Default Re: Fuel Pressure Regulator Vacuum Question... (sumoboy)
Don't do it. The vacuum source is there to raise fuel pressure with RPM's. Unplugging the line gives you WOT fuel pressure all the time. You then have no pressure increase as you rev your motor- not to mention possibly running rich at lower RPM's.
Old May 7, 2003 | 05:41 AM
jan-erik's Avatar
jan-erik
Hi.
Siveck is right about the pressure.
The important thing is that the regulator gives you max pressure when you load the engine and it runs fast. At idle it is important that the pressure is reduced and especiall if you do not have new injectors as it might run rich and the idle will be hunting
Old May 7, 2003 | 07:42 AM
Lone Ranger's Avatar
Lone Ranger
:nono:
Old May 7, 2003 | 08:40 AM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Thanks for the heads up...
To Fuel Pressure Regulator Vacuum Question...
