Proper plug gapping
Old May 7, 2003 | 03:15 AM
black_89_vette's Avatar
black_89_vette
Default Proper plug gapping
I am currently running NGK TR6's gapped at 0.038. I have the TR6 due to my nitrous application. I also am using MSD 6AL ignition and Taylor Spiro Pro 8 mm plug wires. I read in an archive that someone said to run plug gap at 0.035 for nitrous.
Question is..what benefit would the 0.035 have over the 0.038 plug gap during nitrous and non-nitrous use? 99 % of the time, I am running without the nitrous on, so would having a different gap size affect nitrous and non-nitrous application performance?
Old May 7, 2003 | 10:52 PM
black_89_vette
Default Re: Proper plug gapping (black_89_vette)
Nobody has any answers????
Old May 8, 2003 | 01:31 AM
GRX's Avatar
GRX
As you increase cylinder pressures (ie nitrous) jumping a spark across a given gap becomes more difficult. Hence a shorter gap for nitrous (or a beefed up ignition system). Optimally, you want to run the largest gap you can for ignition efficiency.
65Z01's Avatar
65Z01
Cruise-In II Veteran
My guess is that NOS changes the breakdown potential of the charge compared with a NA application, so the closer gap.
For a NA application you can run wider gap with a HO ignition setup; e.g. I run .045" with my HyperTech coil/cap/rotor & TPIS wires, along with cut-back electrodes.
Since going lean is the big fear with NOS I think you would be ok with either setting; if you decide on .035" it will also be fine for NA operation as that is the stock setting.
To Proper plug gapping
